350 tbi/tpi Frankenstein
Old 01-31-2012 | 10:39 PM
grayghostv6's Avatar
Car: 1988 camaro rs/ 1991 camaro rs
Engine: 2.8 v6/ 5.0 TBI (soon to be TPI)
I've got a 305 TPI from an '87 trans am I was thinking about swapping into my '91 Camaro 305 TBI but have decided to go the 350 tpi route instead. I found a good deal on an '87 350 TBI motor and was thinking about swapping the intake setup off the 305 TPI onto the 350. My only question is what is the difference between 350 TBI heads and 350 TPI heads and would I benefit from swapping my 350 TBI heads for a set of 350 TPI heads?
Old 02-01-2012 | 08:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 350 tbi/tpi Frankenstein
Yes. The B2L heads are decent heads. The L05 heads are pretty much trash. I'd also strongly suggest that you pick out a new cam. The L05 cam was terrible. An inexpensive, mild flat tappet cam for that L05 will make a world of difference
Old 02-01-2012 | 10:32 AM
I was told by a couple people to pull an LT1 cam for it but i'm thinking there's probably something better in the aftermarket world for a good price without getting too drastic.
Old 02-01-2012 | 01:26 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
LT1 is factory roller lifter. In order to use it, the LO5 would have to have been machined for those provisions (the casting is roller-ready, but sometimes the machining wasn't finished for truck engines).
Speaking of good deals: http://sdparts.com/details/scoggin-d...er/sd8060ratpi
Then use an LT4 Hot Cam in it.
Bubbajones_ya
07-06-2024 08:32 PM
TX-SleeperC5
02-24-2016 01:34 PM
FormulasOnly
09-10-2015 09:07 PM
FtrSpeedy
09-07-2015 12:11 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: 350 tbi/tpi Frankenstein
