How do I set the initial timing on a TPI motor?
New to fuel injection, and could use some advice.
Thanks to some helpful members, I now know I have a '90-'91 TPI setup (Speed Density with $8d mask id) on a ZZ4 crate 350 short block. The motor runs fine when running but starts awful. There's a loud metal-to-metal clanking after a few normal cranks, which to me sounds like the motor kicking back from the initial timing being too advanced. Once it catches though, it purrs.
But I don't know how to set the initial timing. Or what to even set it to. The GM spec sheet for the ZZ4 says initial timing should be 8* BTDC, but I'm pretty sure that's for a carburated application.
I think the right setting is 0. I think I need to disconnect a connector right by my ECM (because it has a tag on it saying so). But that's about it. The ZZ4 has the distributor on the back of the motor (not an poti-spark style), so I presume I can put a dial-back timing light on the balancer and turn the distributor like any other motor I've had.
Can anybody point me in the right direction?
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: How do I set the initial timing on a TPI motor?
it sounds to me like it is your flexplate hitting your starter. may need to shim the starter. If you are using the tpi style distributor,which i assume you are,then set the timing just like a tpi car. What timing cover and balancer are you using?
1 Post
Axle/Gears: 3:42
need more info. What car is this in? Stock harness? Zz4 balancer and timing cover? Do you have a knock sensor?
To me it does sound like starter-to-flexplate contact, but I don't think it's shimming because the noise isn't constant. I'll get 5-10 normal cranks before the clanking. The starter is new (that was the first thing I tried. It made the same noise with the old starter.
I'm not sure what a TPI distributor is exactly. Mine sits on the back of the motor and looks like a small cap HEI, but without the interal coil. There is a separate coil-looking thing on the passenger side of the motor. The coil, cap and rotor are all brand new. The distributor was on the motor when I got it. The GM paperwork says the distributor shaft needs a melonized gear for the cam in it, so I presume it has that. Is that what you mean by a TPI distributor?
Distributor ans coil
The timing cover and balancer are the ones that came on the crate motor (I believe). The ZZ4 has a roller cam, and the timing cover is a typical looking cover with the words "replace assembly after opening" or something like that (hard to read it behind the water pump).
Balancer (viewed from below)
Also swapped O2 sensor, coil, rotor, did a compression test, swapped the starter, checked all the wires.
1 Post
Axle/Gears: 3:42
The motor is in a 1940 Ford streetrod. The harness is not stock - I believe its a Painless harness. It dos have a knock sensor, and we've swapped that out with a known good sensor to rule that out.
So you are using the 1227730 ecm for speed density cars (1990-92) right. Just make sure you have the EST connector and if you do,then disconnect it and set the timing like you would any normal tpi car.https://www.thirdgen.org/settingtiming
theshackle
09-17-2020 08:26 AM
Iroc8t8
08-26-2015 08:14 AM
