Safest way to lift an engine??
Car: 91 Formula
Axle/Gears: stock
I'm about to reinstall my engine. I'd like to do it all in one go, if possible, so that means transmission and all the accessories already in place. This would make things so much easier, the transmission is pain to install with the car on stands.
I'm thinking I'll have to come in from the side since the nose of a Firebird is so long and I don't really have enough room to come in from the front.
How do you guys attach the crane to the engine? I've seen lifting plates placed under the intake manifold bolts. I'm not sure if this is the correct way to do it? Seems like a lot of stress on bolts threading into aluminum heads. What is the safest way to do this?
Additionally, any problems hoisting/installing the transmission and engine already connected?
Thanks!
Thanks!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Safest way to lift an engine??
The threads in the head for the manifold bolts are more than strong enough.
You might want to get an engine leveller, especially if you'll be putting it in with the transmission installed.
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Take off the hood, radiator, nose and crash bar, get the car up high, run the lift in the front, use a load leveler.
Have some space in front of the car so you can bring the engine forward while it's level, then when the trans is over the engine bay tip it back at an extreme angle to drop the whole thing through. Throw a creeper under the car to catch the tailshaft so it doesn't smack the ground.
You will spend more time fighting the nose than you will R&Ring it IMHO.
how did you get it out?
absolutely install it with the tranny attached
it's not going in with the accessories or headers mounted
but, the good news is that you'll have the hoist there so installing the headers is duck soup once you get the engine somewhat situated
Oh, now is a good time to remove that silly metal pipe that runs from the heater core to the radiator. Your headers are going to contact it so yank it out and use a hose in place of that pipe
Car: 91 Formula
Axle/Gears: stock
Good stuff guys..so I'll make sure not to install the accessory brackets or headers. I can see why that might be a stretch to fit in.
Is it impossible to guide it in with 2 or 3 guys without a load leveler? I'm just borrowing the hoist and don't have access to a leveler.
And just install the lifting plates at opposite corners of the engine?
Thanks again.
Thanks again.
It is difficult to do without a leveler in a thirdgen because of the fixed upper core support. I would check around and see if one can be rented or borrowed locally.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
http://www.walmart.com/ip/Torin-Jack...veler/14560057
http://shop.advanceautoparts.com/web...T%7CGRP2042___
I bought my leveler from Autozone and worked fine.
Thanks again.
Thanks again.
3rd gen
i still had the front clip on because i was eventually going to remove it in the future for painting
tranny and engine bolted together
1 chain on diagonal sides of the engine
floor jack with a 2x4 poised and ready under the car
my car was on generic floor jacks with a click or 2 left so they weren't even all the way up
lift engine way up
push hoist forward
push down on tranny as you lower and keep pushing the hoist forward
set tranny on the 2x4 and slide it backward a little
seriously
you're worrying over nothing
Yeah-I meant the center part of it.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm lucky. With front and rear motor plates, dropping in the engine is easy but I can't do it with the transmission attached. I also need to remove the nose from the car but mine is only held on by about 8 bolts/screws and the headlight plugs. The nose on my car can be removed in less than 5 minutes
As mentioned above, with a transmission attached, you need a leveler. Harbor freight should also carry them.
Also as mentioned above, remove the nose. This may seem time consuming but it will give you a lot more access to push the engine/tranny in from the front. Engine hoists don't roll sideways so going in from the side isn't practical. Unless you have a real good hoist with a very long reach, you'll contact the nose of the car before the engine is in position. Removing the nose allows you to position the hoist right to the firewall. In that first picture above, when the engine and tranny are level, the adjustment will be at the rear of the engine so you need the reach.
Although it's a pain to reach the bellhousing bolts, it can be a lot easier to install the engine, support the back of it then install the transmission.
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
I've had no problems pulling my motor out in both my firebird and my camaro with the trans attacked. Also didnt remove the front bumber, nor did i use a leveler. Just carb plate with a hook on it and pulled the motor.
Everyone told me i had no room with the nose attached, i must have bought the 2 f bodys that had a smaller front end
Car: 87 IROC L98
Or you have an engine crane with a longer than normal reach.
LT1Formula
20
11-14-2015 12:02 AM
