Cam Recomendaton Ramjet 350
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Cam Recomendaton Ramjet 350
I didn't personally run that intake (or complete system) but I hear the ZZ4 type cam that came with the system is easily replaced with the LT4 Hot Cam and it really runs well.
Does that ram jet intake fit under your hood?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
IIRC, the cam that came with the Ram Jet is not the ZZ4 cam but #14097395. Try the Google. It's pretty tame.
Car: 92 T/A 'vert
An L98 cam is bigger than that.
Engine: 2.8/TBI/TPI
...pretty sure that answer is NO...
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Yes, that cam is modest. Show me a stock L98 that does 350 TQ from 1600-5200 RPM. Does a great job of showing the value of a matched package. Threr's a guy in the Fiero community who tried a ZZ4 cam in a RJ350, only did 287 RWHP through a manual trans using Speedway's Tru-Ram cast shorty headers. If you're wanting screaming top-end, you're starting with a way over-priced crate engine you don't want. The 9.4:1 SCR is a bit low for any really healthy cam, especially if you're at any elevation. And that intake manifold doesn't flow all that well. If you have the RJ and must improve it, start with getting the heads shaved 0.030", and bolt them back on with FelPro 1094s to get closer to 10:1. For stock Vortecs, use this cam: http://www.lunatipower.com/Product.aspx?id=2007&gid=281 The better plan is to leave the RJ alone and add boost to up the HP.
Eric-86sc
08-24-2015 09:01 PM
