Non-SBC/BBC chevy swaps...
Car: 1984 Camaro
Engine: 305 HO/ soon to be 4.8L LR4
Transmission: 700R4/ soon to be NV4500
Axle/Gears: Ford 8.8 w/ 3.73 posi
So basically what i wanna see is any non-SBC/BBC chevy engine swaps into thirdgen camaros...
i've seen in a magazine a 2JZ in a second gen camaro and the guy got flamed to no end for it but i thought it was an amazing feat and i just wanna see/hear what people have put into thirdgens...
oh and if there is something ridiculous like a duramax or supercharged ecotec, i wanna see that too...
the reason behind this is i recently procured a VG30DETT from a 300zx and it got me thinking of what that engine could do in my camaro...dont worry though, i'm not gonna try it...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Non-SBC/BBC chevy swaps...
It can do about the same as a drop-in Chevy engine of the same power can, but with a lot more work.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
theres people on here with caddy engines, im sure ive seen a diesel in one, theres even a guy doing an ecotech swap right now. a search through the swap forum would yeild all the info you want.
There is something wrong with a diesel conversion on a Thirdgen to have a diesel sound coming from the car and when stepping on the loud peddle clouds of black smoke bellowing from the back of the car.In my mind it just doesn't fit the car.
Engine: 383 Carb
Transmission: 4L60
Never been outside the US? Diesel cars are all over the world and practically indistinguishable from gas in terms of noise and exhaust smoke.
Car: 91 Camaro RS
that and new deisel engines are quieter than ever and dont produce the clouds of black smoke anymore.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As mentioned in many odd engine swaps, anything is possible if you have enough time, money and fabrication skills. Is it possible? Probably. It's it worth it? Probably not. That's not saying that some weird engine swap shouldn't be done but if you plan on doing such a thing, you're on your own as to what fits and how to make it work.
If you do successfully do a swap such as this then you do have something unusual to brag about and would make a good write up or possibly a magazine article. I've seen a lot of different types of engines swaps. Some are good ideas, many others are not. It all depends on what you want, not what someone else wants.
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Im doing a duramax right now no pics yet but in a few weeks ill start the thread still gathering parts money and research
I would like to have my DMax swap done some time withing a year debateing if I should build the block now for over 1000 hp or get a stock one in tune it to about 600 hp 1200 ft lb tq and then build a second block
they are all canned tunes with efi live it can be tuned to not be rediculous but yes there will be some smoke
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Amen to that...
I'm doing a turbocharged Ecotec Inline-4 swap. Using a 2.4L (LE5) bottom-end (built up with forged parts) and a 2.2L (L61) cylinder-head (offers more cam choices, no drive-by-wire, and no VVT). Add in some basic Ecotec performance upgrades and an Borg-Warner S256 turbocharger. Shooting for 350WHP out of the engine and suped-up Nissan 240SX performance and handling.
More here:
https://www.thirdgen.org/forums/engi...4-3rd-gen.html
Personally, I think the Nissan VG30DETT would make a nice swap. Probably be better than some of the turbocharged 60* V6 builds. Would be even better with more power, too.
More here:
I would do the 4 banger and focus on suspension and then you would have a light and amazing handling auto x car
Car: 87 IROC L98
I've seen a 4 cylinder dragster run high 7 second 1/4 mile. Whole thing probably didn't weight more that 1400 pounds. A small engine that makes a lot of power can be a better choice than a big heavy engine making around the same hp per CID. Of course a small engine trying to move the heavy weight of a full size car isn't going to be as good as a big engine trying to do it. You need that torque more than HP.
Engine: LSJ
Axle/Gears: 4.05
lunati397,
I've already planned on a full coil-over suspension set-up for the car. Pretty much anything Spohn makes for suspension and chasis, will probably find its way onto my car.
AlkyIROC,
It'll all depend on the weight of the car after the swap is done, and it's fully built. I'm also planning on a Harwood fiberglass front-clip, fiberglass hood, the notchback conversion (I like the look, without a spoiler on it), and a rhino-lined interior instead of insulation and carpeting. For a street-car, I'll be pleased if the whole package is under 3,000lbs. Personally, I think it will be more like 2,800lbs., or maybe less. We'll see.
And, if I don't like the Ecotec in my Camaro, I can always put it in my Cobalt.
AlkyIROC,
I looked into swapping a 6BT into my motor home.All diesel engines do have a heavy wt.The 6BT as a example is over 1,000 lbs.It is what makes them durable.The early 5.7 diesels are/where junk converted Olds engines that are prone to cracked heads and head gasket issues.
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
