Are bolt ons easy??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Are bolt ons easy??
"305" and "beast" don't usually go well together.
None of those things is very "hard". How difficult it is really depends on your level of skill, with a little bit of luck for what might go wrong in the process.
Car: 91' Z28
Engine: 383 TPI, 2-305 TBI, 305 TPI
305's are generally the economical 8. You can get a lot more out of them as well as keep the economy though most don't bother. I however just pulled the 383 out and put a 305 into my 91 Z28. With easy to perform bolt on's. Modifications you can do without pulling the engine. Is yours TBI or TPI?
Car: 91' Z28
The key is the same. Air, fuel, ignition, exhaust. Without doing the heads which I wouldn't recommend unless you pull it out and then why not do the bottom end to freshen it up as well there are a number of bolt on's to increase or bring a little beast out of a 305. High flow intakes, larger throttle bodies, adjustable fuel pressure regulators, high fire coils and wires, headers, 3" exhaust and the much needed aftermarket chip. These are various and depend on your engine system but if your at all mechanically inclined achievable. Reducing the power drains with roller rockers, delete a/c electric water pump, and installing billet brackets and pulley's. There are not many who think of my 305 as anything but a beast and it still gets 28+ @ 80 on regular fuel. Of course the real beast 383 was quicker to the finish line and the gas pump, and to an empty wallet with the price of premium fuel plus additives. Things you can accomplish with a highrise and big carb.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
from your question i take it you have not done any . advice , take it slow , learn about engines . put a holley 650 4 barrel on a l03 , will do nothing but drain fuel & wallet . do a good tune-up first , work with what you have . take it slow and research , see/read what others have done . start (after a good tune-up) with intake & exhaust . with out research and a lot of thought you just pi$$ing into the wind . good luck .
Engine: gone
Transmission: gone
Axle/Gears: gone
Upgrade to a 350, you have better head options, will make more power. and pistons etc are more readily available.
Car: 91' Z28
The guys are right about 350's being part friendly but if you want HP and Mileage that will get you further than the next gas station learn about fuel injection. That 305 as my avatar pulls the front loose and I'm sure it will get it off the ground if it didn't scare me to death. I can re-tune it and have made long highway cruises from GA to TX at 28+ mpg and if you can do that carbed then go for it. You just can't beat the rev's you can put out or the gas mileage you can make. They will tell you you can't find tuners. Learn to do it yourself.
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Car: 1985 Z28
Just make sure number 1 is at TDC.Leave your wires in place and take the cap loose and lay it aside,Put in the new dist with the rotor pointing in the same place,should be close to pointing at the # 1 cylinder.It helps to put a mark on the engine where the rotor is pointing with a sharpie before you pull the old one.Put the cap on and remove the wires from the old cap one at a time to the new one.Should fire up.Every time I've done it like this it has only needed minor timing adjutment.It also helps to get a corrected cap if your running an HEI.Cleans up the wires too.Just my 2 cents.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
true, just try and find flat top pistons for a 305! if your lucky and you have a 87 and up roller block, i find that reducing friction is a way to free up extra power. also blueprinting the block helps as well as does a good balancing job. roller tip rockers from comp cams 1.5 for the intake 1.6 for the exhaust.realistically you can achieve 340 hp and 370 ft lbs torque from a 305 AND get 20+ mpg.good luck!!
Car: 91' Z28
Car: 91' Z28
UltRoadWarrior9
09-02-2015 08:24 PM
