85 Camaro Z28 [ENGINE SWAP]
i got a the car a year ago it has a 305 TBI
when i got the the guy had told me he had rebuild it but im not sure.
i was thinking it would be best to put a brand new motor instead of rebuilding it again and i would like some feedback on what kind would be best without having to replace alot of parts.
i know the transmission would have to for sure
would this be an alright engine? or should i go with something beefier?
im not into racing i just want it to run nice
4-bolt main with 2-piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Plugs are Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
http://www.jegs.com/i/GM-Performance...oductId=752506
Car: '85 Z28
Axle/Gears: 3.23 posi
Re: 85 Camaro Z28 [ENGINE SWAP]
Great looking car. Brings back memories. I think most guys will tell you that pre-85 engine with 2 piece seal is leak prone. I can't understand from your post whether your current engine runs fine, bad or not at all. If the rebuild was a quality one, and its running great now, leave it be. You have the reliable TPI setup that should be troublefree for a long time to come, unlike my orig car. By the way great looking car. Is that the orig paint?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If it's an '85, it didn't come from the factory with TBI.
It either came with TPI, or a carburetor.
theshackle
03-05-2017 06:37 PM
112, 1985, 383401, 85, camaro, connecting, crankshaft, engine, lobe, lt1, picture, rods, separation, transmission, z28
