tbi 305 to 350 carb
Car: 1992 camaro rs convertable
Engine: 350 tbi
Transmission: auto
Axle/Gears: 3:08 posi
tbi 305 to 350 carb
i have a 92 camaro connvert rs. i want to replace the 305 tbi with a 350 and a carb. i am familiar with the fuel delievery prob i will have.im not sure on what year motor, heads. like will my old serp belt set-up work? will the headers i have on fit? motor mounts? starter? radiator? flexplate? can i use my old stuff? any info would be great....
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
'85-earlier, your flexplate won't fit.
'79-earlier, you may need to drill, tap, & ream another hole in the block to get your starter to fit.
'69-earlier, your serp system won't bolt to the heads.
