350 swap
Car: Camaro RS
Engine: 3.1l v6
350 swap
i have a camaro rs and it has a factor 305 i have a 350 block that im going to build and put into it (TBI) without changing the TBI i was wondering if i could use all of the following parts without having problems running the car:
COMP Cams CL12-600-4 - COMP Cams Thumpr Hydraulic Flat Tappet Cam and Lifter Kits
Eagle Specialty Products B13402E030 - Eagle Street and Strip Rotating Assemblies
Fel-Pro QKS2600 - Fel-Pro Gasket Kit Sets
Manley 43150 - Manley Stamped Steel Rocker Arms
GM Performance 12495499 - GM Performance Head Bolt Kits
Summit Racing SUM-151124 - Summit Racing® Vortec Cylinder Heads
Any input would help if you suggest another part please link the part and i would appreciate a reason that you suggest it
1 Post
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Re: 350 swap
yea, I would do the same, I've already done what your doing I've got a 91 that had a 305, changed put a standard 355 in it. My block came out of a 93 chevy pickup so I ordered a master rebuild kit for that block and only changed the block and cylinder heads in the whole operation,(increased piston size .030 over)vortec heads. I just put everything else factory over it that I had. Well other than the computer factor I would definately find out the year of your block it might make a big difference towards what you can do to it.
Car: Camaro RS
Engine: 3.1l v6
Re: 350 swap
so this cam would work?
COMP Cams CL12-256-4 - COMP Cams Xtreme Energy Cam and Lifter Kits
this is why i ask on here cause i wasnt sure if i would have to retune the ECM or get a bigger intake thanks
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 350 swap
I know nothing about cams and such, so "fine tuning" might be a factor, but ...
can he not just get a prom from a 350TBI car (like a truck or caprice), use a 350 TBI knock sensor, and 350 TBI injectors?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
In the TBI forum is a sticky about a budget 350. It starts with a Vortec engine. If you're using Vortec heads, it's basically the same thing (if your block is roller lifter compatible). The claim is that can be done without ECM tuning (although I believe a later truck ECM is recommended).
Look that over, and you should have your answers.
About the rockers, it's not clear whether those heads have slotted or round pushrod holes - i.e., whether or not you need self-aligning rockers. Sine the heads appear to be intended as stock Vortec replacements, it is a reasonable assumption that they are assuming self-aligning rockers like the factory used (it does say no guide plates). If that is the case, those aren't the right rockers. Regardless, I'm not sure I'd spend the money on stamped steel, anyway.
The last cam you linked should be fine, although I wouldn't make a call about whether or not you'd still have to do some chip programming to get it running correctly.
