Ford 302 in my 3rd gen
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
No I'm not joking and no I do not want to hear any negativity or comments about me "bastardizing" my Camaro. I want information only.. Let's keep it civil in here please.
There is an adaptor plate that mates a Ford 302 to a 700R4. That solves my transmission and rearend issues. I've heard of Mustangs with SBC's in them but not the other way around for Camaros with SBF's in them. Well except for one 1st gen. So, anybody heard or know about this sort of swap. I'm starting the teardown of the Camaro in August of this year.
FYI, I want a non-GM V8 or V6. I love the 302 but wouldn't be opposed to the 4200 I6 or the Ecotec S\C I4. I dont go to the track and I don't street race so I don't care about "omg a 350 is cheap power!". I only have 2 criteria; needs to make a good noise, can do 0-60 in less than 6 sec.
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: Ford 302 in my 3rd gen
Front mounted oil pump and front sump pan going to cause some major interference problems with the Camaro crossmember.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
to be honest, if you're going to do something to "be different" the ford 302 isn't the one to do it with. you could easily do a turbo 4cyl that will move the car out well, sound halfway decent, and get good gas mileage with awesome throttle response.
i like the ecotec idea...
Engine: Cammed 6.0L LSX
If those are your only two criteria, then why are you wanting to do something that doesn't make any logical sense and spend more money than is necessary. A good GM v8 sounds good, and will get you to 60mph in under 6 sec. I'm not trying to argue here just trying to understand your logic (or lack thereof).
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
A solstice or sky turbocharged drivetrain would be cool as hell but they aren't exactly plentiful. Stock should put roughly 250hp to the wheels. With a tune, good exhaust/intake it will make 300rwhp/330ft-lb all day. Decent aftermarket also.
Quick check I did.. engines can be had for $2000-4000, transmissions auto or manuals for $500-1500. also... those aren't complete ready to drop in engines, probably complete longblockS.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
302 would be a giant waste of time. You won't get your desired results out of that motor with the increased weight of a thirdgen. Even the foxbodies stock had problems pushing any real power without serious modifications. I would recommend a 351 if you were going to do that considering the parts are the same for 90% of it, and the size is fairly identical. You can also stroke the 351 out to a 393 for cheap(er), and easily get the power you're looking for. As far as what else is needed to swap - I couldn't tell you. It's not a common thing, so my guess is you're going to need to do some fabricating on your own.
There's many good reasons why you don't see Ford motors in Camaros... I'd be suprised if you got much useful information here.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ditto on fitment issues with the pan.
302s while being a motor that can take abuse have NO damn torque.
People put sbcs in Mustangs as sbc generally are cheaper to build and have better parts available but that gap is narrowing.
Now I did read about your O.P but what about a 327 if youre looking for a short stroke motor?
Its always easier to do dentistry through the top hole.
I would suggest that you head on down to the local drag strip and look at as many 3rd gens as you can that have a fabricated front end. That is where you're heading. Ask the owners what was involved, costs etc.
Oh, and I'll be waiting wth baited breath for August to see photos of this build
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
ive got no usefull info but i would say go for the 351 never heard of this even being considerd,would be cool to see something else besides a sbc in every thing
Ford 302:
Engines Size liters /
cu. in Horsepower / Torque
ohv V8 5.0 / 302 205-225 / 275-300
ohv V8 5.0 / 302 245 / 320
GM 305:
ohv V8 5.0 / 305 170 / 255
ohv V8 5.0 / 305 220-230 / 290-300
While I do appreciate the objective tone of the post and not being negative if I was going to do a 327 I might as well do a 350 for around the same money, either way I would be just another SBC 3rd gen Camaro. I want to break the mold and do something different. If the car has to sit in my garage for 5 years while I save up to pay someone to do the engine swap for me that's fine. I've got another car to drive daily and I can live without driving it--already been driving without it since Dec. 26th 2008.
Plus, I'd rather put a 3.1L V6 and put a huge turbo on it than stick another SBC in it.
Headers can be fabricated though can't they? Infact fabricating those wouldn't be that big of a deal--just going to cost some $$$.
from personal experiance, and friends 302's. they dont handle alot of power. im not sure if thats why guys drop sbc in theres, but i would go with a 351. if you have nothing but time, it wouldnt hurt doing some fab work. maybe see if theres a company that makes a k member for other motor swaps.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
It's not a bolt in simple as that. If you have some fab skills the world is your oyster. If not move along. That is all I will say.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Vonkaiser - I still own a Thunderbird Sport 5.0 with a 351W in my garage getting ready for a drop-in. I play on both sides of the pond, so I do understand what you're getting at. I really suggest if you want to go the CHEAPEST barebones route while being sensible about it you: buy a late roller 351W block, convert it to hydraulic roller, pull the heads off (because e7 heads are not worth a crap even when modded) and put a set of Trickflows or at the least GT40's/GT40P's on there with 1.7RR's and a decent intake of your choice (NOT BBK), and I guess if it really comes down to it - call Lemon's and get them to fab you a set of longtube headers. They would do it right for a perfect fit.
VonKaiser - I still own a Thunderbird Sport 5.0 with a 351W in my garage getting ready for a drop-in. I play on both sides of the pond, so I do understand what you're getting at. I really suggest if you want to go the CHEAPEST barebones route while being sensible about it you: buy a late roller 351W block, convert it to hydraulic roller, pull the heads off (because e7 heads are not worth a crap even when modded) and put a set of Trickflows or at the least GT40's/GT40P's on there with 1.7RR's and a decent intake of your choice (NOT BBK), and I guess if it really comes down to it - call Lemon's and get them to fab you a set of longtube headers. They would do it right for a perfect fit.
When the time comes I may reach out to you for help if you wouldn’t mind. It’s hard to find someone who’s actually helpful on either a Camaro forum or Mustang forum. LOL
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
That's definitely some good info! Thank you. I'm not planning any "serious power". All I care about is noise (which I prefer the Ford over the GM anyway) and enough scoot to get me 0-60mph in less than 6 seconds with my car at 3,200lbs wet. A stock 351W would do that with ease even with my 700R4. I’d only ever want to do full exhaust, intake and heads anyway so no serious internal engine mods are planned. Those mods on a 351 would give me all the extra power I would ever want anyway.
There's also a place that reworks GT40P's called Tristate. If you can't find a used set of 40P's, they'd be the way to go.
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
If I ever did a conversion such as this I would definately go to something way different like a 2JZ supra motor with a 74 mm turbo. The sound of exotic and the obnoxious ability to be fun!
Many years ago I had an Lx 5.0 minimal mods it ran 13.9 N/A 5 speed with 3.73s it ran good no doubt about that! Well, I had damaged the headgaskets. Car sat for a bit since I had a few z28s. Got my hands on a low mileage 5.7 from a wrecked 90 formula so immediately I looked at the stang 2 weeks later I was done. Slp 2600 stall,vette servo,pulley kit,custom ram air through the ford fenderwell. The car ran 13.4 so 5 tenths faster similar mods minus the 5speed...
I guess my point is you will need to mod the 5.0 just to get the same performance from a stock 5.7 its power to weight.
Whatever you decide have fun and enjoy the fabricating to me that's almost as fun as the first drive.
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
I'm working on it, have the engine on a stand in the garage but have yet to install it. I'm planning on going motorplate/midplate. The midplate serves as an adapter plate for the transmission (powerglide).
Axle/Gears: 4.11
Powerglide too? Youre a real sick one lol. Yup.
Def. have to mod the 302 with a PG to get 0-60 in 6
No C4 or C6, forgot about the AOD trans too.
If you can get past the pan thing you could do this Im sure.
Car: 1990 formula
My junk will do 0-60 in less than 2 seconds on radials with the powerglide transmission. Easily.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Just grab a newer GEN III or IV in there and enjoy the way it will run all over any older SBC or SBF with stock long block parts.
Otherwise, the appealing idea of a smaller engine, I4 or so with boost, that is cool, less weight and the PSI to make ti roll out, just a great time waiting to happen.
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
i know ya wanted a non gm v6 but this is a thought ive been running thru my head.. finding a typhoon/syclone 4.3 turbo. it would bolt right up to the mounts and trans. even if the whole engine couldnt be had, the intakes are out there on the sy/ty forums. just have the intake converted for vortec head pattern and run it on a vortec 4.3. food for thought... the only thing i can suggest is looking into an aftermarket k member. whole lot more clearance and adaptability for motor mounts.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
You can turbo anything, a 4.3 is a 350 minus 2 slugs, so i assume it will take 20 PSI with the right tune and some decent pistons.
I knew the 4.3 is literally a 350 with 2 cylinders hacked off. Would I need a Sy\Ty intake and exhaust manifold to do the turbo? Or are there aftermarket ones? I totally wouldn't be opposed to the swap. But let's get back on the 302 topic. I might go visit a Sy\Ty forum for info on this topic though.
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
Here i an idea......maybe
1989 tta set up
http://www.austinthirdgen.org/forum/...showtopic=4879
1989 tta set up
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Axle/Gears: 4.11
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
If it were me - I'd stuff a mild 454 in there. That's not something you see every day in a thirdgen, and it's plenty for what it is, even if you don't modify it. The only reason I don't have one in my car is because my money is already spent on a 355. I'm "being different" because I'm actually building the engine from what I've learned, not what other people tell you to do. If you base purely off of opinion - you'll never be happy because you didn't really learn anything aside from other people's opinions.. regardless of how "unique" it is.
i found 2 or 3 sy/ty intakes for sale on one website. of course theyre expensive, but it would be unique as hell. for manifolds, id just have some stainless headers made. but i know that bmr and spohn make some k members with the ability to put your own mounts on it. also AJE racing make a k member that might fit the bill too.
Hello,
1989 tta set up
1989 tta set up
i wanna say in the 400 range for it.. i think. i havent looked in a while. been concentrating on my LT1 swap that is now underway.
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
didn't someone in here swap a turbo'd buick motor in a third gen? it wasn't one specifically from a GN or GNX, but it was the idea.
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
you should look for a wrecked explorer for parts as the later models utilized alot of the gt 40 parts i hear. better intake and heads? my brother owns a 98 so i here about it everyday.....
My brothers are into Fords and both have Mustangs. I feel you on the sound part. We put together an exhaust system with 1 3/4 inch long tube headers into dual 3 inch with x pipe and cherry bomb pro mufflers. It makes one of the most beautiful sounds I have ever heard from a car. Why not do a 5.3 LS motor? You can pick them up all over the place for 500 bucks or less with low miles, and they sound amazing. It has a lot to do with the firing order. Fords use a different firing order on the 302 HO and it makes a great sound. The LS motors also use a different firing order and make a great sound. And there is a lot of info out there on the swap. They make plenty of power and are very tough to boot.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I will agree that the 302 is one of the best sounding engines. I am curious if you could get away with using a Tubular K Member and fit the 302 oil pan. Might be worth looking into.
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
If you're kicking around a 4.3L V6 swap, take a look at some of this:
http://www.hotrod.com/techarticles/e...ild/index.html
http://www.hotrod.com/techarticles/e...all/index.html
https://www.thirdgen.org/forums/engi...-4-3-swap.html
The GM 3800 would also be a good choice, considering all the parts you can get for them.
http://www.zzperformance.com/grand_prix/index.php
#42
vonkaiser said the teardown would start in August. So, you guys are kind of late here. He no doubt purchased the 302 and has the plans laid out. It would be good for him to update this thread.
#43
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
BLASPHEMY!!!!!!!!!!!! take him to the edge of the village and stone him!
#44
Guest
Posts: n/a
#45
none of that matters.
vonkaiser has made up his mind. he will no doubt be back to let us know how the swap went.
#48
Guest
Posts: n/a
You already used the stoning joke. Or are you feeling a bit militant about this?
I would do a 393W if it was an easy bolt in, and if there were great heads at a great price, but I'd also do a Dodge Magnum 5.9 if it was an easy fit and if there were great heads at a great price.
But choice of car shouldn't have much to do with which small V8. Only the fact of a buildable V8.
#49
Guest
Posts: n/a
Ok, the front dizzy allows moving the Ford back, but then you need a shortened driveshaft and a shortened torque arm. And will the transmission dipstick tube now fit?
That might get the oil pan out of the steering linkage.
So, weld in a new crossmember forward of the steering linkage, weld in another a bit behind the F-car crossmember, then cut the center out.
#50
touchy touchy... what doesnt make sense is that for those swaps youd spend MORE money then using a chevy at least the 5.oL is a cheap option.. btw im about to drop in a gt40p based 320ish hp 5.0L that I BUILT in my wifes mercury mountaineer this weekend
and dodge magnum 5.9!? everyone(except for you maybe?) knows that they dont make good heads for them because they suck... if its not the new fake hemi it sucks
i really dont care what someone does with a car they own, i was just having some fun... millitant no jovial yes, relax seanjohn
