Retrofit Roller Lifter
Car: 86 T/A
Engine: 305 TPI and 355 TPI in progress
Transmission: TH700R4 w/Trans pack and vette serv
Hi guys,
I just got my set of roller lifter and I spent hours trying to instal them. This may sound stupid but, how do I install these?
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Retrofit Roller Lifter
They should just drop into the lifter bores with the alignment brace connecting to them facing inside the motor.
Car: 86 T/A
It seems like they need the perfet alignment. Those don't just drop in the lifter bores and it's a real pain in the ***!
Car: 86 T/A
Yes they're dry, but it's not for the final assembly. I'll have to disassemble the engine after. They're supposed to enter in their bore even if they're dry...
Car: 86 T/A
I soaked them in oil took them out after 5 hours, no change. Those are Howards Cam lifters. The first I insert go in very well but the second one just don't want to go in...
Car: 86 T/A
Second lifter
Car: 85 Firbird
Engine: 406
Transmission: 700r4 built
Axle/Gears: 3.42 posi 10 bolt
My comp set was a pita. I just had to look at it the right way and they would go in.
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
My thought would be make sure the lifters are parallel when dropping em in. Either that or just try a different couple. dunno.
Car: 86 T/A
I took some picture of them so you can see what I'm talking about. And even if they would enter the lifter bore, there's to much height difference between the lifter( much more than the cam lift)
![](http://img703.imageshack.us/img703/7650/hpim3267.jpg)
Uploaded with ImageShack.us
![](http://img690.imageshack.us/img690/18/hpim3268.jpg)
![](http://img267.imageshack.us/img267/5933/hpim3270y.jpg)
![](http://img703.imageshack.us/i/hpim3267.jpg/)
![](http://img690.imageshack.us/i/hpim3268.jpg/)
![](http://img267.imageshack.us/i/hpim3270y.jpg/)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,722 Likes
Why are you trying to put big block lifters into a small block?
SBC link bars are shorter and don't have those 2 kinks in them. The lifter body itself is the same, only teh link bar is different.
Get the right lifters and they'll drop right in.
Car: 86 T/A
AHAH! They send me the wrong lifter.... On the box it's written SBC Chevy........
KO1
16
10-15-2015 05:00 PM
skinny z
10-05-2015 06:23 PM
