LT-5
Old 11-02-2010 | 02:25 AM
ducefour24's Avatar
Car: 1992 RS
Engine: 3.1L MPI V6
LT-5
okay I have a 92RS 3.1L auto and my friends dad has a 94 ZR-1 corvette with an LT-5 engine. Which the insurance company totaled. The motor and tranny are fine and he told me its for sale. He told to make him an offer for both. I have no clue on how much to offer him can u guys give a ballpark.
will it fit in my 92?
and will it be ok 4 smog i live in Ca?
Old 11-02-2010 | 03:55 AM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: LT-5
Those engines are not cheap the price for replacement parts for that engine will blow your mind its a tight fit in a corvette and they have no fenders.
It would be pretty cool if you could fit it in the camaro plan on doing some major wiring changes along with the lt5 ECM and the complete smog equipment from the lt5.
After you get it running you will have to go to a CA smog referee to have it inspected and get a sticker so you can smog it.
You will need the tyranny too so you would want the hole car so say you got it for 5 thousand that would be a really good deal for you.
If you do get it ill purchase the rear end from you for my Corvette.
Old 11-02-2010 | 11:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: LT-5
Like 92RS mentioned, those motors are NOT cheap. They are worth a small fortune. Additionally, parts are difficult to come by (and very expensive), and as he also mentioned, it would not likely be an easy swap. Plus, though 400 hp is certainly impressive, those motors were high rpm winders that offered little low end torque. Even if I had access to one cheaply, I'd go in another direction, most likely LS-based.
Your money can be far better spent elsewhere.
Old 11-02-2010 | 11:34 AM
Stephen's Avatar
Car: 87 GTA
Re: LT-5
GM did it into a 3rd gen, so yeah....It is entirely possible to fit. DO IT!
http://www.gmhightechperformance.com...aro/index.html
Old 11-02-2010 | 08:10 PM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: LT-5
The rare engine Ive seen on ebay went for $10-15k. With tranny and all the other small parts probably will jack the price up significantly
Old 11-02-2010 | 08:16 PM
Twin_Turbo's Avatar
Re: LT-5
More pics of the GM car, took a lot of cutting. note the crossmember? Also you'll need to fo something to fit the slave cyl. Looks like it's in the stock location here, which means there's some clearancing done to the floor
Old 11-03-2010 | 06:37 PM
ducefour24's Avatar
Car: 1992 RS
Engine: 3.1L MPI V6
Re: LT-5
ok so i went and actually look at the car not even worth the work. It look like i would need the jaws of life just to get the engine/trany out. So i passed but my dad gots a friend in his car club w an ls1 w auto trany w 20k on both and he let it go for 3500
and how hard will this swap be/ how long will it take est.
and last how much u think ill spend on doing the whole swap?
Old 11-03-2010 | 06:48 PM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Re: LT-5
If the engine isnt hit, it's still worth a good bit. Cutting the chassis off the drivetrain is nothing out of the ordinary for wrecks
3500 is way high for a stock LS1/A4 dropout. It better have a long list of expensive mods for that price. Read the sticky on difficulty, time, and cost
Old 11-03-2010 | 07:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: LT-5
with 20K miles? thats not a horrible price... i see 6spd LS1 drop outs go for 4000-4500 with more miles than that
Old 11-03-2010 | 08:04 PM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Re: LT-5
You can buy a whole car for $4500-5000. Dont go buy the ebay yard prices. Surf 'tech and youll find them for $3000 or less with a T56. Less for autos
Old 11-03-2010 | 08:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: LT-5
Just what my local shop sells them for and they sell a BUNCH of drop outs. I did buy a salvage title LS1 TA from them for 5500 with 81K on it...auto/ls1/2.73 gear car. Motors/trans is what is worth 90% of the money. Shells not so much.
Dominic Sorresso
07-18-2015 05:47 PM
Dominic Sorresso
05-29-2011 04:09 PM
Dominic Sorresso
11-20-2008 02:42 PM
HOT/A377
04-19-2001 12:25 AM
Quick Reply: LT-5
