Ecotec I4 in a 3rd-Gen Camaro
#251
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Re: Ecotec I4 in a 3rd-Gen Camaro
LOL! If you want to donate four extra-small turbochargers, four intercoolers, and a supercharger set-up, I'll give it a shot.
#253
Guest
Posts: n/a
LOL! I'm kinda the same way. I frequently have to bitch-slap my inner child and tell him to sit down, shut the **** up, and wait his damn turn.
Funny, my roommate owns both a Starion and a Conquest. He's...quite enamored with those cars. Why, I don't know, but they make him happy. I don't know if someone has done a 5.2L Magnum V8 into one of those cars. Personally, I think it would be a little much, especially twin-turbocharged, for that small of a car. But, that's just me...
Really? I hate V8's? Wow...I didn't know that.
Huh. I could of sworn I owned a V8. Yeah, I think I own a 383ci stroker SBC engine. That's a V8, isn't it?
A running 383 NOT powering anything...
You must have a Camry or an Accord, right?
#254
Engine: LSJ
Axle/Gears: 4.05
LMAO! I'd hope if I had children they'd be born naked. Who knows what cuff-links would do to my woman's vag. LOL!
That 383 would have destroyed the leaking, worn-out TH350 transmission someone had swapped into my Camaro. Let's not even talk about how bad the rear-end was. I could've dropped the 383 into the Camaro a year ago, true, but it would've gone maybe ten miles, with the gears trailing a half mile.
I don't consider it a "running" 383 because I didn't buy it with an intake system. The Weiand single-plane isn't even installed, it's just sitting there.
LOL! My daily-driver is the car I have listed in my sig. If that's "ban-worthy", oh, well.
#255
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Gotta love thinking outside the box. You get to poke fun at everyone else who cant find the exit sign.
#256
For a long time I kept seeing this thread bumped without any real progress! Subscribing for real progress updates now Good luck with the build!
#257
Engine: LSJ
Axle/Gears: 4.05
travis401,
It always amuses me when someone not even close to my area of operations tells me how I should be doing things. I'm the guy with "boots on the ground" and his "dick in the mud". I'm very good at making decisions under stressful conditions, and this is not even close to what I consider a stressful situation.
88gunmetalgta,
LOL! Yeah, mostly a lot of hot air being thrown around this thread. Real progress is getting closer.
88gunmetalgta,
#258
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
That would be quite amusing, but nonetheless completely useless.
Found a pic.
#259
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
The more amusing something is the less useless it becomes.
#260
Engine: LSJ
Axle/Gears: 4.05
White'89,
I don't know about "useless"...I doubt there would be any "turbo lag" on that set-up. LOL!
Pillsbry10,
LOL! I found that line of logic quite...fascinating.
Pillsbry10,
#262
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
I'm not using the VVT head so I don't have to worry about the VVT, which is still a bit of tuning headache, and because of the greater selection of cam options for the L61 cylinder-head, which do not fit in the VVT LE5 cylinder-head.
#263
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
that is definately a justified reason. this project you have going on has me thinking about putting one in my s10. since it's a 96 I'll need something that is obdII, and the ecotec is definately a very good answer. I'm very interested in the mounts you come up with to the subframe.
#264
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
If you want to throw an Ecotec into your S-10, this will probably interest you:
http://www.ecotecforum.com/forums/sh...-s10&highlight=
It's a really LONG thread, but it's very thorough.
The mounts for your S-10 will probably be different than the mounts that get made for my Camaro. I don't think the K-member's are that similar between the two...
Good luck with your swap!
#265
Car: 86 Camaro Z28
thank you. I just found that site, and started to look through it. I understand that there would be some differances, i was just looking for some ideas.
#266
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
Oh, well, for now, I'm considering having some polyurethane "plates" cut, about 1" thick, and those will go on the K-member. On top of that, a piece of steel plate cut to the same shape. From that, a tube welded to it that goes to a plate bolted to the engine block. Not solid mounts, a little bit of wiggle-room for the engine/drivetrain, and simple to fabricate.
Oh, if anyone has an idea of why this is a bad mount idea, please, chime in.
#268
Engine: LSJ
Axle/Gears: 4.05
ronnjonn,
Something like these?
http://www.energysuspensionparts.com...ion-Mounts.asp
I didn't find any polygraphite stuff from Energy Suspension. Mostly just polyurethane. Am I looking in the wrong place?
I did find some polygraphite stuff at Performance Suspension Technology...
#269
Car: '89 GTA
Engine: 5.7L LS1
Lodging a piece of poly between your motor mount and k-member may not be a good solution(assuming I understand you correctly), because that would leave ALOT of wiggle room for the bolts going through everything into the k-member. Pre-made universal mounts like suggested would be better and just modify everything else to fit.
Oh, and with 4 tiny turbos you would get plenty of volume of air, but not much pressure. Pressure = fun
#270
Engine: LSJ
Axle/Gears: 4.05
White'89,
I'll be the first to admit that I don't know much about fabricating engine mounts. Let alone fabricating mounts with a bushing involved.
I'll look into the universal mounts and see if I can find a better alternative.
LOL! While I think four turbochargers on an inline-4 engine would be cool, in a way, there is no way I'd do it. Multiply the complexity of the turbo system by at least four, multiply the cost by at least four, and don't really get much better results than a single turbocharged system. Novel and cool, but...ABSURD.
#271
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Didn't you already have some factory mounts from the junkyard engines? I think you had two left sides or something like that?
Anyway, those used the little round rubber "donut" style bushings. A call to PST and I am sure that they could source you a set of body mount bushings that are nearly the same size.
#272
Here's a link to a 4x4 truck build that has plenty of ideas for mounts using a standard cylindrical bushing, like you would find on the end of a leaf spring. 4x4er's use this type of bushing EVERYWHERE. Take a look: http://pirate4x4.com/forum/showthrea...r+mount&page=4
#273
Engine: LSJ
Axle/Gears: 4.05
KrisW,
I have a set of new mounts and brackets for a Solstice, but I didn't think they were going to work as well as my idea. However, now that it seems my idea isn't as smart as I thought it was, I'll re-explore those mounts and brackets I already have. When I was playing with them earlier in the year, it seemed that two of the intake/driver-side brackets would be easier to play with.
88gunmetalgta,
Thanks for the link! I'll take an in-depth look at it when I have more time.
88gunmetalgta,
#274
Engine: LSJ
Axle/Gears: 4.05
UPDATE - SNAFU
Well, this project is going to be delayed for about a month more. I'm not getting as much from the VA in GI Bill payment this month, so I can't afford the TKO-500 transmission until early next month. I know people were hoping to see some REAL progress on this, so I'm sorry for disappointing. This is extremely frustrating for myself as well...
#275
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
Our government hard at work screwing it's own people. Go figure..
#276
Engine: 2.8/TBI/TPI
Well, when it comes to it, you need to focus on your first obligation and get done with schooling. Better to have your education instead of your GI Bill.
Speaking as a vet, I can say that.
Then when you're making some REAL money, you can do some really fun things.
Keep up the hard work...
#277
Engine: LSJ
Axle/Gears: 4.05
19camaro83,
Oh, the stories I could tell on that subject. LOL!
KrisW,
Yes, my education is my first priority. My living conditions come second, and my Camaro is probably down at third/fourth. I got a pretty sweet deal here in Illinois. The state government pays my tuition, via the Illinois Veteran's Grant, and the VA pays me my GI Bill payments. Hell, that's what I've been living off of for the last year. Fifteen hundred bucks a month has to cover rent, groceries, bills, and other costs of living. Whatever's left goes towards this project. Just another month...
KrisW,
#278
19camaro83,
KrisW,
KrisW,
#279
Engine: LSJ
Axle/Gears: 4.05
Yep, I'm bumming in DeKalb, IL. I was at ThirdGenFest 2010, but I couldn't make it this year. I'm hoping to have the EcoteCamaro to the point where I can at least limp-drive her over to ThirdGenFest 2012...
#280
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
not to thread hijack but, do you have the montgomery gi bill or post 9/11 gi bill? how big of a pain in the *** is it to get the va to pay you every month?
#281
Engine: LSJ
Axle/Gears: 4.05
72vega,
In my situation, with the Illinois Veteran's Grant, I get more money, about $1,500 a month usually, using the Chapter 30 G.I. Bill. Then, after using the Chapter 30 for 36 months, I can apply for 12 months of the Post-9/11 G.I. Bill, and that'll yeild about $1,200 a month. All I have to do is jump on the VA website and verify my enrollment once a month, and go to Military Student Services here on campus to register for the Chapter 30 and IVG benefits before each semester. Not too much of a pain in the ***.
#282
Car: 91 eagle talon awd 438 awhp 390 tq
Engine: 4g63t with HX40 Turbo
Axle/Gears: awd
i have not been on here in a while but .. why Eco Tech .. i would have chose the 4g63 being it still holds the world record for worlds fastest 4 cyl and parts are a lot cheaper
you can find any 4g63t engine 89-92 and it will hold 500 hp its been done numerous times you can find long blocks for less than $400.00
but anyways id still love seeing different engines in these cars
#283
As someone with notaV8aphobia, I got no problems with small forced induction motors.
To me that's what a small motor is for - you free up all that space in the engine bay, lighten up the car, improve the weight balance, get the fancy variable valve timing ... it's BEGGING for turbo plumbing at that point.
What I dont get is the guys who insist on weird v6 swaps... You can still turbo a v6, but it's more complicated logistically... and those things were mostly all dogs from the factory. The ecotecs are a lot better in comparison.
Also... as far as the 4g63...
#284
Axle/Gears: awd
[quote=InfernalVortex;5053241]As someone with notaV8aphobia, I got no problems with small forced induction motors.
Also... as far as the 4g63...>>>>>>
[/quote
[/quote
#285
Axle/Gears: awd
#286
Engine: LSJ
Axle/Gears: 4.05
jyoungst,
While I have a lot of respect for the 4G63 motor and all it's achievements, I could not bring myself to throw a Japanese motor into an American car. Also, I like to stay with the same maker. Therefore, GM engine in a GM car. Also, the Ecotec motor, while it may not have the reputation and following of the 4G63, it is still an amazing motor capable of a lot. Another reason, the Ecotec is an aluminum-block, and is a little lighter than a 4G63. Also, I don't like timing belts, like that that come on a 4G63. The Ecotec comes with a timing chain. Would I shake my head and bad-mouth a 4G63-swapped 3rd-Gen? Hell no! But, it won't be me that builds one.
Oh, and for turbocharging a V6 that came in these cars. Yes, the V6 motors were dogs from the factory. However, if you go with a hybrid top-end on a 60* V6 and add a turbocharger, there are some amazing results possible. Even better if it's a full-on 3x00 V6 swap. It's not that much of a pain or logistically complicated. There's just no aftermarket, already-made parts.
#287
Axle/Gears: awd
sr20s are the same with chains but they are prone to head failures
#288
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Hell put a rb26 or even better a subaru ej20 or 25. But back to topic this is about the ecotec in a third gen. And how the op wants that. Let's not clutter this
#289
Engine: LSJ
Axle/Gears: 4.05
jyoungst,
The SR20 is another fine motor that would make a good combo with a 3rd-Gen. However, isn't the SR20 and iron-block? If it is, why not just jump up to the KA24? Get a little bit more displacement, and I think they're a little more solid of a motor, myself.
91camarosRS,
All those are also good choices. Not a big RB fan, personally. Those motors are little too rev-happy and not enough torque down low for an inline-six in my opinion.
I don't mind this talk. It's the, "You're an idiot for thinking about putting an inline-four in these cars. Do whatever one else has done, and put a V8 in there" talk that grates me.
Besides, hopefully, it won't be too much longer before I have enough damn money to get the TKO-500...
91camarosRS,
#290
Car: 02wrx/88 rs
Being that I have a subaru I love that motor. There is a reason they put them in airplanes. And they sound wicked. I like imports as well as domestics so I love crazy swaps.. maybe even a sweet rotary
#291
Car: 86 Camaro Z28
I had a 92 talon, and to put it out there. I miss driveing the car. now to go onto the problems of the 4g63. The timing belts suck for longevity, lifters always tick, head gaskets blow. I had 2 timing belts go each at 40k, honda I4s go 100k+ with no problem. The belts were from Mitsubishi, I didn't want to do it a second time. that's leaving the transmissions out of it because it wouldn't apply here. I will give them the credit that when they're running good, they run great. but as a swapping motor, unless it is strictly for racing, why put in an engine is that will constantly need laborous work done to it so often.
#292
Axle/Gears: awd
still happy to see something different !!!!
#293
Car: 86 Camaro Z28
different is good. after the tbelt went the last time, I almost went forward with putting a 3rd gen tunnel and kmember into the talon. it would've been fun. i can't wait to see this ecotec in the camaro. no one will expect it. by the way I found this t56 adapter, if you ever want to go 6spd. http://www.thegearbox.org/catalog/it...17/4803441.htm
#294
Car: '89 GTA
Engine: 5.7L LS1
Talk is cheap. No one goes through the headache of swapping and making motors and transmissions fit and work without making some serious considerations.
Fallen did his homework.
#296
Car: 91 Camaro RS
ive got that adapter in my car, it allows the t56 to bolt to the ealier style sbc bell housing (like the stock one). wont do anything for bolting a t56 to an i4 or anything that doesnt have the sbc bell housing pattern.
it also requires the longer ls1 input shaft for anyone considering it. (or just the ls1 version of the t-56).
#297
Car: 86 Camaro Z28
it can be paired up to this http://quad4rods.com/index.php?page=...&Itemid=100041
or this pair
http://store.fab-tek.com/custom-fabr...llhousing.html
http://store.fab-tek.com/ecotec-to-c...t-adapter.html
or this pair
#299
Car: 91 Camaro RS
i bet the t-56 with the i4 would get some crazy gas mileage cruising down the highwaay in 6th...
#300
hahahah 60mph.... 800 rpms... 100 miles to the gallon
