Ecotec I4 in a 3rd-Gen Camaro
#551
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Re: Ecotec I4 in a 3rd-Gen Camaro
Well, I decided to not wait to get the entire K-Member/tubular A-Arm/Coil-over kit, and get the stuff separately. It'll only cost me an extra $125.00-ish, in the long run...
So, I ordered the Spohn Tubular K-Member, only. Should be in my orbit in a couple weeks, at most.
#552
1 Post
Car: 92' RS
Engine: 305 TBI
Transmission: 5 spd
I think this will be a pretty cool setup when your all done . anything thats outside the box is cool and with the right setup you could pull v-8 hp numbers from an ecotec
#553
Engine: LSJ
Axle/Gears: 4.05
adclass,
That's what I'm hoping. Well, power numbers of a mild- to moderately-built V8. That would be fine.
The K-Member arrived a couple days ago, but, now, I have to find the time to wrench. Updates to follow...hopefully, soon.
#554
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
I'm really curious to see the gas milage for dailly driving, and the end result of power.
#555
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
Won't know for sure until it's done...
Here's the progress that I made over the last couple of days. Dropped the stock K-Member and A-Arms, and bolted in the Spohn tubular K-Member. The K-Member that I ordered came without motor-mount pads, per my specifications. The stock-placement motor-mount pads were too far forward and high to be useful. After a little more puttering tomorrow, I'll start the mounting planning...
#556
Yay progress!!
Curious, why front coilovers? I thought that was kinda a drag only thing on third gens. I thought they limited wheel selection and were in general a PITA to work with.
#557
Engine: LSJ
Axle/Gears: 4.05
88gunmetalgta,
Hmmm...that's the first I've heard about coil-over's being a pain on 3rd-Gen's. I'll look into that more...
The reasons I want to go coil-over's is so I can adjust the ride-height more. I have a feeling that stock shocks and springs would cause the front-end to sit very HIGH.
Rebound and stiffness adjustment would be nice, too.
#558
Car: 1987 Trans Am
Engine: LQ9/L92
if you want adjustable on these cars, go weight jacks. since our struts and springs are separate by design on these cars, the additional diameter of the coil cuts down on what's available for room behind the wheel. weight jacks would use the stock spring location while allowing for different spring rates and heights.
#559
1 Post
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
#560
Engine: LSJ
Axle/Gears: 4.05
I still plan on using coil-over's. I'll be running the same size tires as caffeine, and I'm not looking for extreme amounts of camber.
After a little more puttering, today...
I actually get a little more room using the LNF intake-manifold than the plastic intake-manifold's.
Still plenty of room on the exhaust side for the turbocharger, down-pipe, and other necessities.
This is the closest interference. This steering-arm bushing gets within about 1/4" away from the top of the oil-pan during its full steering arc. Still, enough wiggle-room.
The oil-pan clears the K-Member, just as I predicted, and the bottom of the oil-pan doesn't go much lower than the lowest point of the K-Member. Thankfully, I wasn't planning on lowering the car that much.
Now, as for the actual mounting of the engine, current idea/plan is to modify the mount from a FWD application, weld a piece of tubing to it, and that will span the distance between the frame-rails. Polyurethane bushings will be used.
Unfortunately, there's not much of a better way that would still be secure.
That's it, for now...
#561
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
looks great man.... now clean your engine bay
#562
Engine: LSJ
Axle/Gears: 4.05
Pillsbry10,
Yes, Master! All in good time!
Thinking about sand-blasting it, painting with POR-15, and than putting bed-liner over that.
Probably same procedure for the under-body. Good thing I have a rotisserie...
#563
lol i felt i needed to say something negative. does look good though i might have to see that car in person someday
#564
Engine: LSJ
Axle/Gears: 4.05
Pillsbry10,
LOL! It's all good, man. I still have plenty of rough patches to go with this project.
This car will be on the road plenty when it's done...
#565
1 Post
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Very cool swap! I love unique powerplants in our thirdgens! keep up the good work!
#566
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I think it is a pretty cool and very practical swap. Now to swap in a junk 4 banger, i would not like, but that is a nice engine.
#568
Engine: LSJ
Axle/Gears: 4.05
neilb,
Thanks for the support!
ZONES89RS,
I could have started with the good old "Iron Duke", or a Honda 4-cylinder...
Awesome-X,
Yeah, room is not an issue. I can literally stand in the engine bay!
ZONES89RS,
Awesome-X,
#569
Car: 86 Camaro Z28
you would be surprised what a honda K-series can do. combining V-tec and cam phasing is pretty serious stuff.
#570
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
Apologies, I should clarify: I was referring mainly to the D- and B-series Honda engines. The K-series engines have something the D- and B-series don't...ENOUGH DISPLACEMENT.
#572
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
A very fortunate consequence of having 2.0-2.4L of displacement, DOHC, and VTEC.
#574
Engine: LSJ
Axle/Gears: 4.05
ZONES89RS,
What about a Mazda 13B rotary?!
#576
Could be cool as hell.
As for the 50k mark? I only put about 5k miles a year at most on my GTA. Its summer only and even then nice days only. But I'm not afraid of driving it in the rain, if there is an event planned and the weather is iffy I'd still take the GTA out to the event.
*Cept Snow. The Nitto NT05's would be slicks on ice.
#577
Engine: LSJ
Axle/Gears: 4.05
LOL! Apex seals don't appeal to me. Besides, the 13B is actually heavier than an Ecotec.
I have no idea how often I'll drive this car when it's done...
#578
Car: 85 camaro z28
Engine: 355
Transmission: t-5
so whats the horsepower gonna be like? Any estimates? I know you need a good amount to really get a thirdgen moving.
#579
Engine: LSJ
Axle/Gears: 4.05
NathanLewis,
I estimate, with my current combination I have planned, around 350WHP with good spool-up and similar torque numbers.
The amount of power needed to get this combination moving probably won't be as much as you think. A lot of weight is going bye-bye with this swap...
Or, at least that's my estimate.
#580
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
This is awesome! So glad I stumbled across this thread. I have been hush hush about my build, but I am in a process of putting a 2.2l I5 in my car. I'll be watching!
#581
Engine: LSJ
Axle/Gears: 4.05
68Strat,
Welcome to the party!
A 2.2L Inline-5? Do tell more. An Audi engine? Just curious...
#582
Car: 85 camaro z28
Engine: 355
Transmission: t-5
NathanLewis,
#583
Engine: LSJ
Axle/Gears: 4.05
NathanLewis,
That's one of the side-perks I'm hoping for!
#585
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Got a stock one bolted in yet, while you're trying to assemble an over-boosted one?
#586
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
Unfortunately, not yet. Finances are really tight, right now. No school also means no G.I. Bill payments or pay for being a tutor.
Hopefully, one of my Army buddies will pay me back some money he owes me...SOON.
Atilla the Fun,
The project probably won't progress like that. I have a lot of other stuff to do to the car. She's still basically stripped down, right now.
Oh, and I may have found an economic and practical way of going supercharged instead of turbocharged. In the long run, it could be even cheaper than going turbocharged. But, it's a lot more up in the air if the supercharged combination would hit 350WHP. Have to rethink my method of forced-induction...
Regardless, will order the materials for the mount when the funds are available.
Atilla the Fun,
#587
fallen u can get a turbocharger for 118 bucks, look at fasteddis thread for the links
what is the redline on that motor if its low then that turbo may be a lil large but they do have a smaller version for the same price.
since u already have the manifold u just need the turbo and wastegate + plumbing which is also very cheap if u use mild steel mandrel bends
#588
Engine: LSJ
Axle/Gears: 4.05
project89,
Yeah, I could get an eBay turbo, but I'm not a fan of 'em. I've seen some that are good, and I've seen some that suck. If I'm going to buy a turbo, I'll buy one that is GREAT.
The turbocharger I'm looking at is quite similar in size to FastEddi's. A Borg-Warner S256 (Non-ETT) to be precise, and they work beautifully on 2.0L Ecotec's. And, since my motor will end up being 2.3L, would probably spool up even better.
I got the manifold for a great deal, and could probably sell it for what I paid for it.
I just got to do some brain-storming. This part of the build is still a ways in the future. Getting the mount finished and having the bottom-end of motor built come before this.
We'll see...
We'll see...
#590
Engine: LSJ
Axle/Gears: 4.05
mike22115,
You're not the only one, man. Welcome!
#591
Car: 1982 Z28
Engine: LC9
Transmission: AR5
I did a quick scan but didn't see it mentioned so I apologize in advance if it has been mentioned here before (did a search for Corvette Ecotec, and nothing came up for this link) ...
Anyway, there's somebody doing an Ecotec swap in a C4 Corvette:
http://forums.corvetteforum.com/auto...build-log.html
Building the car for autocross, and the car can carry a lighter minimum weight if it uses a four cylinder.
Pat
Pat
#592
Engine: LSJ
Axle/Gears: 4.05
slow305,
Now, that's SWEEEET.
I've never heard of it, but thanks for showing me that. One hell of a read!
And people think what I'm doing is BLASPHEMY...
#593
Car: 86 Camaro Z28
I looked up that turbo, and some of those dsm guys are putting down some serious power on a 2L. I know it's the ETT model, but still 500AWHP is no joke.
#594
loving the build, keep it up!
#595
Engine: LSJ
Axle/Gears: 4.05
diablizzard,
Yup, those turbo's are loved by the DSM, Nissan SR20, the Cobalt, and some of the Honda crowds on engines about 2.0L of displacement.
ericjon262,
More coming up...someday. LOL!
ericjon262,
#596
Engine: LSJ
Axle/Gears: 4.05
Looks like someone had a similar idea to what's been rattling around in my head...
"As you see above my 2.4l VVT Ecotec I have a M90 Supercharger adapted to GM's tricky water to air intercooled inlet manifold making the need of a front mount intercooler obsolete. A few other things where needed like lower compression from 10.4:1 down to 8.5:1 and H beam rods ect to give me an expected 350BHP."
http://daewootech.com/forum/viewtopi...=13465&start=0
Making 350BHP with 8.5:1 CR, stock LSJ heat-exchanger, and stock top-end ain't bad. That's almost 300WHP.
Hmmm...P&P'ed cylinder-head with 1mm over-sized valves, ditch the stock LSJ heat-exchanger for an air-to-air intercooler set-up, and a 9.5:1 CR...could make 350WHP.
#597
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I think in the LONG run you'll be happier if you go turbo. It seems to me there is a lot more "tuneability" if you can call it that. I know that's not a word, hahahahha.
I just mean, when I look at my choice of engines, the Buick V6 (and derivatives) the turbo stuff seems to be much more flexible to changing this or that, and the later supercharged stuff seemed to be more rigid in its tuning characteristics. Especially valve train wise. The stuff I have read makes a big deal out of optimizing valve trains on supercharged engines due to not being able to vary the boost as much. Turbos have such a wide range of boost that can be run you have a lot more range to work inside of. Basically you can just plug in your wide band O2 sensor, and adjust your fuel to the given boost you have your turbo set for (within your turbo's parameters, of course.) The cam really only needs to be set for low overlap to optimize the boost building. When you get enough air flow, the cam starts to become irrelevant. I've seen the old Turbo Buick engines get those heavy tank cars into the low 12's with a stock 87 camshaft. The supercharged 3800 cars always need a cam and rocker change because they just can't get the boost.
Either way, I can't wait to see how it turns out.
#598
Yep, I prefer turbo...
If I was to use a supercharger it would not be a roots style at all, due to the heat they tend to generate. I would use a centrifugal style, being a more efficient compressor and heating the compressed air less than a roots style.
That being said, I do love how a roots style blower sticks through the hood on old muscle cars, and such.
#599
This is really a cool build, I used to have a 84 4 banger camaro and loved the fuel economy of it just hated the performance. Would be cool having a 4 banger f-body with around 200-250hp. I have a 97 3.8 camaro now while not the fastest car by a long shot it gives near the economy of a 4 banger 3rd gen and the power of early v-8 third gen. Too bad chevy never supercharged the 3.8 or grand nationalized it.
#600
Engine: LSJ
Axle/Gears: 4.05
Yeah, this is what happens when I don't have money. I have way to much time to think and my imagination goes off in a million different directions simultaneously.
I do know this: I'd be happy with the results either way. Supercharged or turbocharged, the car will be fun as hell.
After looking at the compressor map for the 5th Generation M90 supercharger, which is what came in the last two years of the Thunderbird Super Coupe, it COULD flow the amount of air I would need. However, that would be spinning the supercharger pretty fast, therefore increasing the parasitic loss. Also, these superchargers make a lot of heat. Heat and pressure would be big hurdles, even with an air-to-air intercooler in the system, to making 350WHP. While cheap, not the best idea.
I have sent a few inquiries for information about the Harrop HTV1320 supercharger, though. These are a Twin Vortices Series supercharger, and their efficiency...WOW. Peak efficiencies in the low 70% range. Not as efficient as a good turbocharger, true, but still very impressive. Also, this supercharger would easily make my power goal, especially with the air-to-air intercooler system. Many others have used this supercharger in their Cobalts, and have impressive results. Only problem, EXPENSIVE. However, if you were to calculate the cost of a QUALITY turbo, wastegate, and BOV, it might be as expensive as a used HTV1320 supercharger that I could modify to work in this application. But, then, I'd have to have a custom long-tube header made, eventually. That'll be a bit, a BIG BIT, more expensive than a custom downpipe for the turbocharged set-up.
For now, I'm stuck which way to go, right in the middle. But, I've gone back and forth on other things before, too. I guess I've gotten used to a supercharged powerband driving my Cobalt SS Supercharged around all the time. However, I do still remember the fun I had driving my Army buddy's 350WHP turbocharged KA24 Nissan 240SX around the backroads on Bragg. It's a tough call. Both ways have their advantages and disadvantages.
Ugh...I need money, so I don't have so much damn time to think...and rethink...and rethink...and rethink...etc.
Anyways, sorry for the rambling. No updates...YET.
