350 build up. Need your help
Car: 1984 Berlinetta
Axle/Gears: 3.08
Hey guys, I have a parts list put together and I want your input. If all this will work together. Tryin to make a streetable but something where i can run with an 03 cobra (my buddy).
350 block 4 bolt main stock
Vortec Heads #12558060
High volume oil pump
Double roller cam chain
edelbrock Performer intake
comp cam xe262 cam
msd hei billet distributor
edelbrock exhaust manifold with air tubes
Stage 2 q-jet
Procharger 600b supercharger or 142 weiand mini supercharger
Holley high flow mech. fuel pump
3" inch magnaflow exhaust muffler
3.43 rear gears
700r4 tranny with shift kit stock tq converter
Yes I need all the emission equipment and i live in Texas sorry ac is a must to keep.
comp cam xe262 cam
Stage 2 q-jet
3.43 rear gears
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 build up. Need your help
That's not gonna do it. And while nitrous and porting might get you close, it's still the wrong cam. But if he's done even just a pulley to that Cobra, then forget it. You'll need an AFR 180 headed 383, at a minimum, to have any real hope.
1 Post
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
If it's goin in your 84 all they need to see is the cat convertor. put a good tune and you will pass the test now in texas. deffinitely follow Atilla's advice for getting to your power level also you might study up on Atilla's best builds.
