swaping out my lo3 305 to a 350 carb
Car: 1991 Camaro RS, 1987 Firebird
Engine: 305 TBI, 350 TPI
Transmission: 5 Speed, Auto
Axle/Gears: N/A someoone tell me
im about to swap in a 350 carb motor into my camaro. right now it has a 305 tbi in it. i was woundering what all im gonna need to do to swap this in. like will it bolt right up to my t-5 trans or will i need and adpater plate. this is my first swap so if you can give me any helpful tips that would be great. thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What did the 350 come out of?
Are you planning on putting the TBI back on it, or downgrading to the carb?
Re: swaping out my lo3 305 to a 350 carb
it came out of a 1982 corvette and i plan on makin it carb
Car: SOLD!!!!!
downgrading??? its a tbi. i tried all avenues and my carb runs way better. but you have to be willing to tune it manually. if want it to be easy then keep the tbi. i still say that a properly tuned carb will flow and run better. but you have to manually tune it.
Engine: LS1/LQ4
A carburetor isn't legal on a '91 model year in any of the 50 United States.
Of course, neither is an '82 engine.
You will need a different flywheel. EFI to carb is documented in the tech articles linked from the TGO homepage (also in the "welcome to the carb forum" sticky).
Car: SOLD!!!!!
also if he looks up my name i did a good write up. leagal???????????? come on. lol!!!!! if inspection is a priority and less tuning go tbi. if all out and inspection is not an issue go for carb.
yeah inspection aint a problem will the motor mounts that i have now work or will i need new ones
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Ive done the swap myself and yes you can reuse the 305s motor mounts. The t-5 will bolt up as long as you use a 153 tooth flywheel. If the vette motor is a 2pcs rear main, you cant reuse the 305's flywheel. A new 153 tooth 2pcs rear main flywheel isnt cheap either. Youll have to either rework your stock engine wiring harness to work with the new engine, make your own, or only plug in the parts you need on the new motor and leave the rest unconnected. There is a great write up on how to modify the stock harness (which I used for my swap) in the LSx/LTx swap forum stickies entitled "How to prep a 3rg gen harness." Youll also either need to change your fuel pump to a mechanical one or carb friendly out of tank electric one with a carb pickup in the tank, or use the stock pump with a return style regulator. Good news is all of your gauges will work after you toss the computer, as long as you wire the water temp and oil pressure senders on the engine correctly.
for a pulg and play harness would i just need a harness that they used in the 1982 corvette or a different one
Car: 91 Camaro RS
That I have no idea about. Im looking at this as just a standard 350 swap. Is the vette motor carbed or fuel injected?.
was cross fire injection also found 153 tooth 2pcs rear main flywheels for like 80 bucks dont know if thats cheap or expensive
Car: 91 Camaro RS
If your swapping to a carb, I think it would be easier to modify your stock 3rd gen harness.
oh ok im just tryin to figure out everything im gonna need to do for this swap my first one. i hope its gonna be a noticable gain in the hp and from the 175 my 305.also would i beable to use any of the accessories from my 305 like alternator, a/c compressure other stuff like that
Car: 91 Camaro RS
Depends on what the vette motor is rated at. If you go from a 305 to a 400+ hp 450+tq beast of a 350 like I did, then yea, you notice a difference
Car: 91 Camaro RS
Engine: LS1/LQ4
Car: 91 Camaro RS
I guess only the billet flywheels are expensive as ****.
now i just have to figure out which type of carb i should run
Car: 91 Camaro RS
If its just a stock 350, a 600-650 cfm carb should be plenty.
im buying a whole new top end kit for it a buddy of mine told me to run a 800 cfm carb
Car: 91 Camaro RS
ive got WAY more power than you and a 750 is enough for my motor.
Car: 91 Camaro RS
Depending on the top end kit, you may need a 700-750 cfm. But I dont see many street motors running 800cfm carbs. Except for the people that think throwing the biggest carb they can get on a motor is a good idea.
Engine: LS1/LQ4
350 x 5500 / 3456 = 557 CFM. That's assuming 100% VE and single plane intake. A dual plane intake typically benefits from more CFM capacity, but a 650 CFM is about all you can expect a mild street 350 to need.
1 Post
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
a crossfire vette motor is one of the most lowest rated hp motors ever put in the vette, a 600 cfm will do fine.....
The swap isnt all that hard to go from EFI to Carb. Me and my dad did it took us a long time but we wanted to make it look nice the hardest part was all the damn wires!!! Just do like my dad did a chair and some time and sort them all. Make it look pretty the first time so you dont one day get the urge to redo it all lol! good luck and I hope you have fun!
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
