Alright in Planning stage, need opinions.
Car: 92 RS
Engine: 5.7 SB
I was finally able to get my car: '92 RS 25th Anniversary v6(bad crank, so i was told)
I plan on swapping the engine with my 383 i have. I need opinions for the intake, i already have a complete 305 tpi set up off my 87 z28, this seems to be a more difficult route, but i'd really like to have the tpi in for looks. i plan on trying to tackle the prom burning and all the tuning myself later on when ready. If i go this route what all will i need to swap the 87 harness into the 92? I've read for hours the last few nights and couldnt find an exact answer.
Another options is i could probably sell the tpi unit for enough to by a decent carb. but would rather go with tpi setup.
also dont have much money, i know going tpi would be a lil more money but im thinking i could pull it off farely cheap, correct me if im wrong.
Everything is up in the air, just going through options.........
Kguffey84
Kguffey84
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Stock, the TPI will absolutely choke a 383. Modified, it doesn't have the TPI "look" anymore.
How do you like the look of a Stealth Ram?
Re: Alright in Planning stage, need opinions.
Yes, the runners and base were designed around a 305. They barely feed a stock 350
HSR is the least expensive EFI intake available. Only thing that may end up cheaper is a 4 bbl EFI conversion intake. Check out single plane EFI swaps in the alternative intake forum
Car: 88 GTA Trans-am
Engine: 350 vortec TPI(in process)
Transmission: 700-R4
Axle/Gears: 3.27 LSD
360.00 bucks, DEPENDS ON YOUR HEADS, Wheather or not the are vortec specific
Engine: LS1/LQ4
Search "stealth ram" on www.summitracing.com . Then click on "Air and Fuel Delivery", "Intake Manifolds", and "Stock Configuration".
Car: 92 RS
Engine: 5.7 SB
Thanks, But i just think i'll go with single plane carb since it's not gonna be a daily driver. what carb setup would work good?
Car: 92 RS
Engine: 5.7 SB
im not sure on any of the specs. i got the engine from my dads good friend. it has to have a new cam and lifters due to improper break in i guess. heads also have to be restudded. i have a race cam from dads old stock car. he said it will work great for the motor.
Car: 92 RS
Engine: 5.7 SB
well we got the engine torn down.... we were lied to lol, not a stroke 383, but stock 350 2 bolt main. owell got the motor free, pistons, cylinder walls all that are good, no play in the crank.
the bad news..
pulled the cam out nice and gentle til the ignition gear. well i made a simple preventable mistake. the block was upside and the fuel pump plunger caught the ignition gear and i did not realize it until i turned the block right side up and puled the cam out. turns out i scarred the bearing up pretty bad. went ahead and ordered new ones just now from jegs. will be in friday. hopefully put in sunday. also got new cam, intake and complete gasket kit in today.
edit: oh yea im goin carbed,
here are the specs
Advertised Duration282° 292°
Duration @ .050"224° 234°
Valve Lift w/ 1.5 Rocker Arms0.4650 .488
Valve Lift @ Cam0.3100 .325
Max Lift Angle109° 119°
Lobe Separation114°
Cam Timing @ .050" - Opens3° ATDC56° BBDC
Cam Timing @ .050" - Closes41° ABDC-2° BTDC
the bad news..
here are the specs
Lobe Separation114°
Car: 92 RS
Engine: 5.7 SB
alright, i am getting ready to order some other things and was wondering if the summit hei distributor would be alright??
http://www.summitracing.com/parts/SUM-850001R/
and my heads are currently at the shopw gettin freshened up, new seats, hot bathed, studs are being either drilled and pinned or pulled, tapped, and new studs. should be done early nest week.
got the cam bearings instralled, dad was irritated but i guess i learned lol.
here is actually my wish list i am negtioning on getting
http://www.summitracing.com/users/wi...5-9a20057f7adc
anyone's input would be great,
Thanks Kohl
Thanks Kohl
Car: 92 RS
Engine: 5.7 SB
ugh, i was afraid of your answer.....
even for a street car? just to have a little fun?
Car: 92 RS
Engine: 5.7 SB
also, he hasnt started the work on them yet, what about the heads off my 87' tpi 305??
Engine: LS1/LQ4
Your 305 TPI heads would actually be better. 1.94" intake valves would help them to be even better.
The 882's would be okay for a street car, but you'd be wasting a lot of your cam.
I hope you were planning on better valve springs, either way.
Have you ever considered Vortec heads?
Car: 92 RS
Engine: 5.7 SB
for vortecs, it's too much $$$ for me.
could i just go with the stock 305 heads for now until i have saved enough money to get the 1.94" valves? would these work?
http://www.summitracing.com/parts/SUM-V8000-8/
Car: 92 RS
Engine: 5.7 SB
also on the 305 heads, if i get the 1.94" valves whats has to be done to the head for them too work?
Engine: LS1/LQ4
These seem to work well in healthy street engines: http://www.summitracing.com/parts/CCA-981-16/
Car: 92 RS
Engine: 5.7 SB
well after discussion with my father i am staying with 882's (what a downer I know) until i can affored The "Meet & Patato's" haha
Engine: LS1/LQ4
The 882's will still need the springs, and most likely will need the top of the guides cut for the extra travel of that cam (good time to go for Teflon valve stem seals).
Does your 350 have dished pistons? If so, I would still consider the 305 heads over the 882's, even if you don't do the larger valves. The amount of work either set of heads would need is about the same.
Car: 92 RS
Engine: 5.7 SB
I did get new valve seals, but not sure if they're teflon, they're whatever come in the summit kit
Engine: LS1/LQ4
Most likely they aren't Teflon.
Be sure to check every valve for travel, with the seal (if the umbrella type that goes over the guide), retainer, and keepers (no spring). You need sufficient travel for your cam lift plus .050-.060".
