What else do I need to consider
I am about to drop a 383 stroker out of a 72 chevy c10 into my firebird (currently 305 TBI). I have taken into account that my T5 transmission will need to be replaced and I might need to beef up the rear end. Is there anything else that I am overlooking?
[This message has been edited by 92birdman (edited November 30, 2001).]
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Just the entire TBI system.
And externally balanced 168-tooth flywheel.
And externally balanced harmonic damper.
And the wholely inadequate exhaust system.
Tell us more about what you HAVE looked at.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited December 01, 2001).]
the problem is I haven't considered much. I found a guy who is getting rid of a complete 350 bored .60 over in running condition for $200. It also has a Dual Energy Competition Cam, ported heads (stock I assume), and an edlebrock performer intake. I'm getting sick of the measly 305, and it's really hard to pass up a $200 motor. ANY help would be greatly appreciated.
Engine: LS1/LQ4
Just keep it a 350 and you'll be amazed at the difference if you do the exhaust as well. I have been pleasantly surprised at how well my 305 runs with what I've done, so a 350 should do even better.
With the 350, you won't have to worry about the externally balanced things, although you will still need a different flexplate since yours is one-piece and a '72 is two-piece rear main seal. TBI mods will be much easier to handle on a 350 - Check for advice with the guys on the TBI forum on that.
Do you have to deal with emissions? If so, TBI is probably the way to stay unless you really go nuts and convert to TPI.
Engine: LS1/LQ4
Humm, you did say the engine came out of a truck originally, didn't you. If so, even ported stock truck heads are no friend to performance.
Some Sportsman II's would wake it up, though.
Thanks for all the help. I do know that I will eventually need better heads, but for now the others will have to do. Money is the main reason for that. If only I was loaded.... It would be nice. Thank you very much again for all your help.
