tpi intake manifold on lt-1 heads
i have the 350 lt-1 but do not want to screw around w/ the wiring and computer will the tpi intake maifold bolt on to the lt-1heads and if not what is interchangeable
87 IROC-Z 305tpi
still $h!ten on
rustangs
87 IROC-Z 305tpi
still $h!ten on
rustangs
You got an LT1 or LT-1...lot different... I would recommend keeping the miniram if your engine is LT1, runner are longer and if you put TPI it will be restricted ...
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
LT1 POWERED
HEADMANS HEADERS
I see, it took me 3 days to do the wiring and start the car. it ain't that much trouble, just being patient.... your LT1 with a tpi will not make more then 250 hp ...it will be very restricted ...also since the TPI is a water cooled intake it will not perform as well since the LT1 as no water running trough the intake ...
My point is, since you have an LT1, why not keep it all stock and give yourself the trouble of doing it ....it's well worth it.
LT1 POWERED
HEADMANS HEADERS
LT1 POWERED
HEADMANS HEADERS
86IROC112
08-17-2015 02:00 PM
