thrown rod
thrown rod
i have a 91 z i just threw a rod in it can someone advise me what and(prices)comes next in a bottom re-build i also figured since the motor is gonna be out to put on headders has anyone experienced this simmilar friggin problem?oh yeh money is also verry tight--need help
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on how much damage has been done. I totally destroyed a 383 last fall when I threw a rod.
If the block survived and you don't need a new one you'll probably need at least
new crank or the old one machined
new con rod
probably at least one new piston
bent valves from hitting the piston
Maybe bent push rods
hole in oil pan?
camshaft and lifters ok?
That's not including all the extras like gaskets, rod bolts etc.
Don't ask for a quote on repairs without knowing how much damage has been done first. Once you do a tear down to see how much damage is done, it can be cheaper to just install a reman engine.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
new con rod
hole in oil pan?
Best 60 foot: 1.546
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
