Want to swap my L98 for an LT1 .........
I Have an 89 Iroc with an l98 350 TPI motor and it siezed because of being flooded with water and a friend of mine has a few 1999 LT1 test motors with 50k on them will my TPI intake fit and will I need a new ECM, MAF, I am not exactly sure what all I will need to do this......
boomride@bellsouth.net
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
if you have the year correct 1999?it isn't a LT1 it's an LS1.GM went with the LS1 in 1998
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Yes I had a talk with my friend last night and they are 1998 LTI's they are test motors and have never been in a vehicle.. I need to know what else MUST be changed to do the swap.....
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
<font face="Verdana, Arial" size="2">Originally posted by CARgoB00M 1:
</font>
</font>
1 Post
Car: 1988 GTA
Engine: 404ci LS2
Transmission: 700R4 Full Manual Reverse
Axle/Gears: 3.91 Australian 9 Bolt
I have done this swap and it was pretty straight forward. If you do the swap you dont want to put the TPI intake on an LT1 block. The biggest shortcoming of the L98 was the intake. The LT1s have great intakes and can make Horsepower across the board. I suggest that you track down an LT1 with harness, computer and all.
88' GTA w/ 93'Corvette LT1 absolutely bone stock
-4,000 stall
-Custom Fabricated"True"Ram Air
-200 shot NX Express
-Southside Machine Lift Bar and Subframe Kit
-11.43 in the 1/4 at 119mph with a 60ft of 1.59 seconds
-488 RWHP and 526Torque
-566 Flywheel HP and 610 LB/FT Torque at the Flywheel
-4,000 stall
Engine: 5.7 HSR
Badass glad you could make it to the party
