350 crankshatt in a 1968 327
1 Post
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hi guys im actually preparing a 1968 327and i have the crankshaft from a 350 and the one from the 327 ...i was wonderin if i put the 350 crank on will it produce more hp??
if you put the 350 crank in it youll have a 350.
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They both use a 4" bore. The 350 crank just has a longer stroke.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
It will work fine as long as the 327 block you have is '68 or later. If it is a '62-'67 block the main journals are a smaller 2.300 vice the later 2.450.
Jeff
Jeff
84 TA NV
09-06-2015 08:02 PM
