maximum power adder for LT1
I have a super small budget of 500$ to put on my 93 LT1 it's rated right now at 285 hp i would like to have around 310hp ...is there something cheap to do that. I'm not looking for gears, headers, catback or muffler add-ons. Maybe underdrive pulleys and a ram-air ??? Any idea folks ???
89 Camaro RS Stock as a women with white panties
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Hey mat i know you said you werent looking for catback but an edlebrock catback is only 275 from jegs and just might give what you want during the swap along with a pair of K&N filters and ramair, just run some ducting up to the factory airbox from the air vents in the bumper.
well if you want to add that much HP you have to be ready to do some work. I bought my flomaster cat back and installed by a muffler shop for only $330. Cat back is probably the first mod you should start with. Do that and buy a K&N air filter....total around $400 and that should give you about 20 HP.
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, and a 160 degree T-stat. 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from [URL=http://www.MrMikes.com[/URL](its nice)
TES Headers in the mail, and about to order a stage 2 fastchip.
I read in an old CHP issue that with a larger throttle body, the lt4 heads and the GMPP hot cam you're good for 400 hp.
I'll scan it and post it for ya, it has the dyno results for stock cam/tb and lt4 head; new TB and lt4 heads; and new tb, hot cam and lt4 heads.
Now I know its not that cheap to do this but I just had to tell ya about it.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Nitrous?
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
383 86 Camaro Z28
COTM Editor
Received 1,923 Likes
Car: '89 Firebird
Engine: 7.0L
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I like the idea for the LT4 cam , thanks Brian, It this lot of work ???, thanks guys for all other info , Can I get more info on the 52 mm trottle body VSS problem...
LT1 IS COMMING SOON.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
