boring 305 to 383
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
boring 305 to 383
As the title says I want to bore my 305 out to make a 383 stroker. My question is how much does it need to be bored out. Sorry I suck at math and I did a search with no luck.
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: boring 305 to 383
you cant. You have to use a 350 block. And its not the bore that makes a big difference in a 383, its the stroke, you change the stroke from a 3.48 to a 3.75.
Engine: 305 TPI HO
so is it possible to make a 383 stroker out of a 305? or should i start looking for a 350 block?
Engine: 305 TPI HO
thanks everybody. I had someone giving me wrong info. I am just going to look for a 350 block and build up from there. There seems to be plenty on Craigslist.
84z96L31vortec
08-20-2017 12:16 AM
gixxer92
09-01-2015 04:32 PM
NinjaNife
08-23-2015 11:49 AM
