carb or tpi
Old 07-08-2009 | 10:16 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
carb or tpi
I hope I dont get scolded for asking. I have a 90 iroc with 305 tpi complete 156k miles not running dont know whats wrong with it. I want to upgrade to a 1999 vortec 350 with 906 heads I have complete motor altho I will rebuild before installing.Will this tpi intake fit? Even if it will, would I be better off putting a carb and ditching the computer? I will be running street,strip.
Old 07-09-2009 | 12:23 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: carb or tpi
If you decide to stay TPI, you will need to get a lower intake manifold, the "base", from Scoggin-Dickey. Once you do that, you then have the option of an Accel Super-Ram. That's great if you're going to stroke it to a 383, which you may as well do if you're gonna rebuild it. The carburetor isn't that much cheaper in the end, and gives up mpg. Plus even if there's no emissions testing near you right now, that could change at any time. If you stay TPI, you'll have great power to 4500 rpm, but then it falls on it's face. The SuperRam is for 383s turning 6000 rpm, and there are other choices like the Weiand Stealth Ram, we all call it the HSR.
Old 07-09-2009 | 05:58 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: carb or tpi
Thanks for info I never have run a tpi motor and think I will being going over 4500 dont know about stroking it unless thats the easiest and affordable hp I hope to be around 400 thanks for reply
Old 07-09-2009 | 08:20 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The Vortec-version Holley/Weiand Stealth Ram (HSR) is about the same price as just the Vortec TPI base. You will need a different throttle body with the HSR, and different fuel rails. But, you would need better runners with the Vortec TPI base, so by the time you spend all that money, you might as well get the HSR.
You didn't mention any specific changes to the Vortec engine, so just the Vortec base and the rest of the TPI stock would probably run okay. If you change the cam, figure on needing better valve springs, and then the TPI would need to be upgraded. If your plan is for power at 5500 RPMs, plan on cam change, valve spring change, possibly valve guide cutting, and a complete aftermarket TPI set-up.
And PROM tuning, of course, since '90 TPI is speed density and doesn't take well to changes like this.
Old 07-09-2009 | 10:02 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: carb or tpi
Thanks Five the heads have already been worked the machinist said they would handle up to .560 lift? So I guess he measured the springs pressure I would be putting new roller cam as big as the heads would handle.Nothing new to block but boring 30 over flat top pistons would have to let it run pump gas
Old 07-09-2009 | 10:08 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: carb or tpi
Forgot to ask this, friend told me he had ecm for 88 caprice that was cop car with 350 in it would that help me any? He has complete ecm set he does not use since he went carb on cop car
Old 07-09-2009 | 10:23 PM
five7kid's Avatar
Engine: LS1/LQ4
No, that would be a TBI ECM.
Old 07-09-2009 | 10:59 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: carb or tpi
ok thanks sounding more like carb all the time
gta90
09-15-2015 05:00 PM
beachrodder
08-25-2015 09:05 AM
theurge
08-21-2015 01:46 PM
86IROC112
08-17-2015 03:00 PM
Sanjay
08-12-2015 04:41 PM
Quick Reply: carb or tpi
