396 to big?
Car: 1992 Camaro Z28
Engine: Bolt On L-98 150shot
Axle/Gears: Stock
396 to big?
I have been looking at stroker kits for my current L98 and I have seen that there is a 396 stroker kit that a few company's make. Would a 396 be a good choice over the 383 or would it fall apart and or not hold up as well as the 383 kits usually do?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 396 to big?
The 396" kits are pretty sketchy on production blocks... lots of guys hit water clearancing the block for that crank/rods. I'd say its a 50/50 chance you'll hit water because so much has to be ground out.
The power gain isn't all that significant over a 383" and its alot safer to build than the 396". If you want that many cubic inches, find a 400sbc and use that. The LT1 guys like the 396" kit, but their heads and intakes breathe alot better, and they don't have the option of using a 400" block. The LT1 castings usually don't have the hitting-water issues as often as the Gen 1 blocks do too, thought lots of them still do hit water.
My advice - build a 383, or find yourself a 400 block.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: 396 to big?
if deciding to buil such serious motor, u might as well go with some serious standard sbc heads and efi intake with 90* elbow.
the tpi heads and intake will kill any potential of the 396ci.
stock heads and intake even struggle to feed stock engine.
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
10-01-2015 07:47 PM
