Stock gauges
Old 03-22-2009 | 10:31 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Stock gauges
I swapped a carbed 350 into my Camaro and Am trying to get the gauges all working now. I dont have a temp sender or oil pressure sender so I wanted to check if these are the right ones I need.
Coolant temp sender
http://shop.advanceautoparts.com/web...GRPSESWAMS____
Oil pressure sender
I should be able to pop these on the motor and just connect a spade connector form the stock wires and it should work right? Oil pressure wire is tan and coolant temp is dark green?
Old 03-22-2009 | 10:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Stock gauges
If those are the right senders for a 1990 Camaro, they'll work.
Old 03-22-2009 | 11:01 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Stock gauges
Well I could only find the coolant sensor thats for the ecm for a 90 camaro. So i donno if that one will work or not?
Old 03-23-2009 | 01:42 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Stock gauges
Ok I changed the car to an 85 carbed maro since thats the wiring harness I am running now and the site says they should fit. Ill give those a try then. Thanks
Old 03-23-2009 | 04:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Stock gauges
You don't want a coolant sensor for the ECM. The ECM doesn't operate the gauges.
Old 03-23-2009 | 06:23 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Stock gauges
Yeah thats what I meant. Sorry my wording was wrong lol
Old 04-01-2009 | 01:50 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Stock gauges
Ok, so I bought and installed those senders and hooke dup the wires that go to the gauges and I get nothing. Only gauge working is the volts one. I am running an 86(carb) engine wiring harness with 90 gauges. Is this a problem? I checked fuse for guages and its fine.
Old 04-01-2009 | 02:16 PM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
Re: Stock gauges
The route i am going is just to buying a a-pillar gauge pod, then get a coolant and oil gauges for it.
Old 04-01-2009 | 04:43 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I wonder if those are switches rather than senders. If so, they won't do anything when operating normally.
Although the oil pressure should peg with ignition on and engine not running if it's a switch.
Old 04-01-2009 | 05:25 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Stock gauges
Well the are both ar zero and not moving. I measered the resistance on the coolant sender adn the resistance changes steadily as the motor heats up. I already hav e a a pillar pod but thats reserved for a couple other gauges
Old 04-01-2009 | 05:26 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Stock gauges
Oh yeah and the oil pressure sender said it was for a 60 psi gauge so i dont think it is just a switch
Ghettobird52
07-06-2024 12:18 AM
Jeremys87
07-14-2022 10:08 PM
ChevyZ71
08-13-2015 08:30 AM
Armored91Camaro
08-12-2015 10:41 AM
