1987 v6 swap to 92 tpi
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
First off, I have a 1987 Camaro that had a 2.8 v6. I now am swapping to a 1992 speed density system on a 4 bolt main 350 out of a 95 vortec. I have everything figured out but the wiring. I have a 92 tpi harness. I figure the right way to do this is to change the pinouts on the harness.
on the 92 c100 connector the black/white wire in cavity c7 says engine. I am unclear what this actually is. Do you know what i switch it to in order to match it to the 87 c100 terminal? there are also many that are on the 1992 harness that are not even on the 87 terminal. what do i do? Thanks a lot for taking a look at this hope you can help
-Jarid
-Jarid
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
http://www.team3rdgen.com/modules/3r.../1987_c100.gif
http://www.team3rdgen.com/modules/3r.../1989_c100.gif
Washer/wiper, perhaps? Wrong color, though.
Car: 1987 LT Camaro
Axle/Gears: 4.11
Re: 1987 v6 swap to 92 tpi
At first i thought it might have been something to do with the wipers but on a 92 i believe that the wiper/washer is on the headlight harness
TX-SleeperC5
09-24-2015 03:13 PM
