305 TBI to 350 carb engine swap
Old 04-10-2009, 05:51 PM
  #51
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Re: 305 TBI to 350 carb engine swap
Man, it looks GREAT. I did basically the same thing.... well sorta, I bought my 90RS with original 305TBI that had already been swapped to a carbed 350. The guy did a CRAPPY job on it so I ended up getting the engine rebuilt and I should be finished with it this weekend. Already got it in and everything. I really like how clean your engine bay looks! I plan on taking the remainder of the A/C out of mine as well (I still have the components attached to the firewall). Have you had any problems with taking the ECM out? I really would like to do that but am pretty nervous about what has to stay and what can go. I hate the look of all those wires in my bay though! Looks great though!!
Old 04-11-2009, 10:14 AM
  #52
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
thanks, i had no problems, i kept the wires for the starter, alternator, disty, and i wired my fan and fuel pump but no problems i hated all those wires, i was happy to get rid of them i also went to after market gauges so i didnt need to keep any of those sensors
Old 10-07-2009, 01:48 PM
  #53
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
I right it has been awhile but i just wanted to up date this alittle.
So i got the motor down and running i put in the 2 speed powerglide
and i went with a 4th gen rear with 3.42 gears. I wnet with corvette replica wheels very happy with them. just a few more things left with BMR then off for paint. I thinking of going with a flat black with gloss black racing strips. but not sure may also go gunmetal. well see. i have to put a cowl on with the crab, spacer and intake hood would not close, go the 4 in cowl for free so not complaining.
Tidan (01-28-2020)
Old 09-28-2020, 06:45 PM
  #54
theFireNation's Avatar
Car: 88 Firebird
Engine: Chevy 350
This looks so similar to my build. Mine was swapped from a 2.7 TBI to a 5.7 carburated in an 88 Firebird. Would you be able to tell me how you hooked up the speedometer and tachometer? That's like the last piece to my puzzle.
Old 09-28-2020, 10:01 PM
  #55
TGO - 10 Year Member
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
2.4 ? Iron duke ?
Old 09-29-2020, 08:26 AM
  #56
Jjw2419's Avatar
I am putting a zz4 in my 85 Iroc replacing my 305 TPI. I am trying to decide to go carb or use the old TPI system. I believe it would bolt on from what I have read. TPI systems after 1987 would need some tweaks. I am going to install headers and remove the cat since emissions isn’t an issue in Michigan. I would like to maximize as much of the HP I can yet like responsiveness of the current TPI. The new Holley carb was going to run me about $500 and guessing should be a push adding my old TPI. Any thoughts would be appreciated.
Old 09-29-2020, 08:33 AM
  #57
Engine: Lb9
Transmission: M20
Should really start a new thread. The tpi is restrictive better off with a aftermarket base and runners.
or hsr, miniram. The 85 870 ecm can be tuned but somewhat difficult to work with.
better off going dynamic efi ebl or 86-89 165 tpi maf ecm resin and add relays or use a 86-87 harness.
Old 09-29-2020, 10:02 AM
  #58
Jjw2419's Avatar
Thanks for the info. I did create a new thread.
Frozer!!!
01-19-2024 04:55 PM
theshackle
03-05-2017 06:37 PM
Jae992
08-27-2015 09:07 AM
92purpz28
08-11-2015 02:30 PM
Quick Reply: 305 TBI to 350 carb engine swap
