Why is the ls1 more efficient?
Car: 85 camaro z28
Transmission: auto to manaul
How come the ls1 is more efficient then the sbc, and why does it get so much better gas milage? Is it because air flows better or location of injectors?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Way is the ls1 more efficient?
its like comparing apples to oranges, better airflow, different borexstroke combo, different materials....too much to get into. bottom line is although i adore SBC i will be first to tell you GEN III motors are 10x better.....
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
A few reasons:
The cathedral port heads give great flow without losing much low end.
The 6 bolt bottom end holds the engine together at high rpms.
The intake manifold allows both low and high rpm operation.
Optimal bore/stroke ratio.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Why is the ls1 more efficient?
Sequential fire injection is arguably more efficient too, as opposed to TPI batch fire.
Car: 1991 RS Camaro
Engine: 350 0.060" over
I'm just theorizing but the aluminum rather than cast seems like it would allow higher compression for the same fuel.
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
aluminum heads yes, block im not so sure about since they have a sleeve.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Most important item....they are 18 degree heads. (valve angle)
That makes for better flow.
The cathedral port shapes are the other...
They work synergistically to allow good low end flow with the top end normally associated with very large cc heads.
Have you noticed lately how many times they have changed the port shape?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
As mentioned by the last few posts, the cylinder head design is 95% of the differences.
