TBI to TPI ?
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
TBI to TPI ?
Can any one tell me if I will need a differant TV and throutle cable I have a 92 RS 5.0 TBI and I am installing a SD TPI I also think I need a differant fuel pump the TPI unit I got is 5.7 will I need to change the chip in the ECU or will it work on my 5.0 any help would be great
Thanks Shawn
lnsper@mchsi.com
Thanks Shawn
lnsper@mchsi.com
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
Re: TBI to TPI ?
Did you read the tech article on swapping TBI to TPI? Did you
and read the hundreds of other threads on this topic?
Yes you will need a new TPI throttle cable.
Yes you will need a new TPI TV cable.
Yes you will need a new TPI fuel pump.
Yes you will need a new TPI computer and chip.
None of those TBI parts are compatible.
![search](https://www.thirdgen.org/forums/images/smilies/search.gif)
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Re: TBI to TPI ?
https://www.thirdgen.org/tbitotpi
This will give you some good direction, and its what Kevin was refering to.
Strangely though, its listed under misc instead of carb/F.I.
Car: 92 RS
Re: TBI to TPI ?
Thanks for the info can you recommend a place to get the 5.0 chip or were I can get mine reprogrammed
Thanks again
Thanks again
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Re: TBI to TPI ?
TBIchips.com
But most here will tell you that you should do it yourself. These are experinced people and thats what theyll tell you.
evilstuie
01-09-2020 08:29 PM
Sanjay
08-12-2015 03:41 PM
