confused bout ECM/CPU between camaro and firebird
Car: 1983 Firebird SE
Engine: 305 5.0 V8
Engine swap:
removed v6 & trans from firebird and dropped in v8 305 & trans from camaro of the same year. How should we handle the wire harness ECM/CPU? What else is needed, what else should i know bout completion of this swap?
Engine: 305 5.0 V8
Re: confused bout ECM/CPU between camaro and firebird
83 we want to stick w/4bbl carb....messages bout exhaust setup is starting to scare me....just found out bout limited space, with no room on the driver side.....
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
To the best of my knowledge there shouldn't be any difference Camaro/Firebird in that year.
The only V6 thing that gets in the way is brake lines - easy to fix.
Engine: 305 5.0 V8
Yeah thanks for the info.....my 305 & trans is from a Berlinetta, I'm going to miss her it's time to let her go far to much rust to work through. As for the exhaust I'm using factory manifolds for now (just want 2 get bck on the road) any suggestions to an inexpensive temporary exhaust. Planning on using factory Y pipe without cat would like to just dump the tail pipe in front of rear tire. What do u think? Summit sales universal round cylinder mufflers for under $50 12inch long w/3" inlet/outlet. Thanks again for the support.
Engine: LS1/LQ4
Where do you live? I've got one I'll give you; y-pipe, cat (looks new), cat-back, great sounding muffler off of a California car.
