Any crate a direct drop in?
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
All the crates are carb'd or too fancy like a LS1. Isn't there anything I could buy, drop in, change and prom and be done?
I'm prepared to beef up the rear and tranny, and even change the hood for clearance.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Any crate a direct drop in?
buy a long block crate motor and bolt ur tpi to it....or a carbed one and yank off the carb intake and once again bolt your tpi setup to it...
Car: '92 Camaro Z28
Thats what I was thinking of doing. How easy is that? Will any 350 work or what?
Car: 1991 Z28 1LE
Transmission: 4l60e
u need a 2 piece rear seal one with the centerbolt valve cover style...u need to know the specs of the engine and cam so ull be able to match the fuel injectors set your prom right... find an engine that u are intrested and post it and we can tell ya yes or no
Car: '92 Camaro Z28
I have 24# injectors on my 305 right now.
Can't I put my TPI on this?
http://www.crateenginedepot.com/stor...41-P18C53.aspx
I see it's the base, I have my 305 running so I can put all the accessories on it so if my TPI can be put do you think this is the way to go? I have to change my prom to the 350 prom but that is simple.
My Dad's friend has a garage with lifts and **** so I have the people to help me.
Car: 90' IROC-Z
Engine: 355 TPI
Scoggins Dickey has two one 300 horse and one 360 horse vortec TPI. has vortec heads with TPI intake. Wish I would have waited.
http://www.sdparts.com/product/SD360...ripEngine.aspx
Car: '92 Camaro Z28
Where is the 300 horse one...I can't find it...$4k is a little much for me.
Car: 1991 Z-28
Transmission: TH700
What information I gathered, when you swap a tpi to any of the carb crate engines, the horsepower will drop around 20-30 hp. That's with a stock tpi setup.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The valve covers don't have anything to do with the rear main seal type. By 1986, all SBC crankshafts were one-piece rear main seal. Not that it matters that much, all you're talking about is a $35 flexplate. '86-earlier heads is a bigger headache, though.
Anyway, a couple of '87-up 350 choices:
New: http://www.sdparts.com/product/12513...RollerCam.aspx
Rebuilt: http://www.rebuilt-auto-engines.com/...24108034860.3f Tell them you're upgrading from 305 to 350, and that you want roller lifters and 083 casting heads (if you order on-line, they will call and ask you some questions to make sure you know what you're ordering). You'll need to reuse all your tin, and the rear main seal carrier.
You will either need to reflash the PROM for the 350, or get a '90-'92 L98 PROM. The 24 lb injectors are bigger than necessary, but will work.
Car: 1991 Z28 1LE
Transmission: 4l60e
wow i dont know what the hell i was smoking right there i meant 1 peice im glad u caught that.... and yeah the pre 87 heads are a bigger headache thats why i said the centerbolt heads and like i just said meant to say 1 piece rear seal...good lil quick visuals to narrow down a search....thanks for the correction....i need to proofread myself now on i guess lol....
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
