T5 bolted on a 350???
1 Post
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
My 305 is crapping out so if i get a 350 can i bolt it up to the T5 without ripping the tranny into pieces??? If no then what are my other standard tranny options. I know there is the t56 but thats expensive. How much and how difficult is it to strengthen up a T5.
1 Post
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: T5 bolted on a 350???
Everybody is gonna tell you that it's a bad idea with good reason. Just think, gm never mated a t-5 to a 350.
1 Post
Car: 89 Formula
Transmission: TH 700R4
Depends on how long you expect it to last. Without serious abuse, like power shifting and others things...I think it could hold up quite awhile (and as long as the 350 isn't too heavily modded)
GM had multi-year/mileage warranty concerns that they had to worry about.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Josh R - if you search the site you will find countless posts on T5/350 combos
lots of comments against it
lots of comments for it
I suggest searching and decide after informing yourself with knowledge and experience of others.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
There are two possible reasons I've heard for that that make sense to me:
1. The T5 wasn't strong enough.
2. An f-body with a 350 and T5 was faster than same year Vettes (and you know we can't have that).
I tend to believe #2 more than #1 (have also heard couldn't get the L98 to pass emissions requirements with a T5 - I don't buy that one at all).
But, T56 is really the "right" way to go manual. However, if you don't do high-RPM clutch dumps or speed shift the T5, it'll last behind a 350 (one notable member had a non-WC T5 behind a 400 for years - but he knows how to drive).
1 Post
Car: 89 Formula
Corvettes still were a bit lighter and had a bit more HP.....no way could TPI 350 5 speed Camaro out run a manual 350 TPI Corvette.
1 Post
Car: Iroc
Engine: 350 4-bolt
as for the vette being slower, it may be possible that they had different gear ratios, tuned more for high speed than acceleration. Maybe. Just saying.
And would it be easier to get a T56 later on. I can't afford to get a 350 and a t56 at the same time. Is it hard to swap a transmission out from the bottom?
Engine: LS1/LQ4
Most often done that way, in fact.
1 Post
Car: Iroc
Engine: 350 4-bolt
ok thanks. So i just won't beat to hard on the T5. I can't wait to be shifting like a Semi and still beating all my friends cars.
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
The t5 should be fine as long as you don't beat on it to much. I run a mild 350 with a t5 and the only reason I had to replace the trans was because it was low on fluid, and I ran it on the highway about 100 miles at 65 or so. And that was a non-w/c. now I have the world class, and so far its running well.
t
Last edited by theorio1025; 08-21-2008 at 03:30 PM. Reason: accidentally double posted
Car: '88 Firebird
Engine: 350 (340 Est. HP)
Transmission: Turbo 350 (1800 Stall Convertor)
Axle/Gears: 3.42 Posi/28 Spline/Alum Diff Cover
so by the way im understanding this a t-5 will be sufficent for a 350, as long as i don't dump the clutch and powershift. my dad and i are preparing for a swap 2.8 to 350, i have the t-5 now in my '88 firebird. Whats the difference between a world class and non world class t-5 ? And none of the 350 factory cars had a manual?
Car: 87 GTA
I see nobody has addressed this..
There was were"basically" 2 different T5s. Your 86 T5 & the World Class T5 (started in 88 IIRC?) that had more splines, bigger input shaft & more.....basically stronger.
Now...A WC T5 is much more likely to live abused behind a 350, than a non WC T5.
Car: '88 Firebird
Engine: LS1/LQ4
WC doesn't have more splines than non-WC. V8 has more splines than V6.
V6 T5 = weak unit that doesn't belong behind any V8.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the clutch disc would need to be v6 also, but this is crazy talk
more thread hijacking: http://www.flatheadv8.org/ernie/ernie-t5.htm
good info on the t-5
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
well currently i am running a non w/c t-5 behind a 383 build and so far so good but i dont beat on it either.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
You will also need a V8 bellhousing to bolt the V6 T5 to the V8. Also, didn't the V6 T5 have different gear ratios not optimal for V8s?
Car: '88 Firebird
so when people talk about not beatin on the t5 do they mean NOT AT ALL or maybe a dump here and a pass at the strip there, as long as it's not all the time?
It seems that everybody has differant luck with the T5's behind a decent engine. I have been running a non WC T5 for 5 years with 300 rwhp. 25-30 passes down the track, some with slicks. I also beat the crap out of it whenever I drive it. The only failure I've had was a broken shift fork which let the broken pieces get ground up and foul the 5th gear syncro. Not a big deal except I was 350 miles from home and have 4.10 gears. Kinda of made a crappy drive home.
The original poster should definately use the T5, if it dies quickly due to driving habits or whatever, then upgrade. It won't explode in your driveway.
Here it is at the track, I am not nice to the tranny.http://www.youtube.com/watch?v=e5Oug24NFBc
1 Post
Car: Iroc
Engine: 350 4-bolt
ok. Then i will use my stock tranny. I sure hope it doesn't blow up in my driveway.
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
I have a Gen0 350 small block and a WC V8 T5 with 2.95 first gear. I put down about 315 ft-lbs at the wheels, but my weight is about 2,500 lbs. fully loaded.
I have no problem at all, but keep in mind that I'm about 800lbs at least below a typical 3rd gen.
