302 questions
302 questions
hello.
i have been thinking for a while about puting a V8 in my 1991 firebird 3.1. I can get a 5.0 from a '83 camaro w/ a 4 bbl would this be simpler to install than a 350 from year-one. and if it is what would i need to compete the swap
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 302 questions
A 5.0 from an 82 Camaro is a 305, not a 302. It's externally identical to a 350, and the exact same work is involved in the swap.
Car: '89 Firebird
Engine: 7.0L
Re: 302 questions
I would continue to search for a 350. The cylinder bores are larger in diameter and provides more space around the cylinder head valves. Any cylinder head you put on a 305 will flow better on a 350 and make a lot more power. Same concept applies when moving up to a 400.
It's not difficult at all to blow the doors off a 305 car. Almost any vehicle on the road today can do it.
Re: 302 questions
Thank you qwktrip.
My dad said that it wouldn't be much better then my v6 anyway. So i guess i will keep searching the classifides for a cheaper 350 because i dont have a mountain of cash to put in into just the engine . on another note will the 700-R4 tranni that is in my car work with a 350 i think it would but i want to double check.
Engine: 383 Carb
Transmission: 4L60
Re: 302 questions
oh i didnt know that. i was flipping threw the year-one speed shop catalog and on page 2 was a reman. 350 W/ 400 hp and 440 LBS/FT i am thinking of putting that in my 'Bird with a Th-700R4 TCI tranni. My friend said it would be a good set-up but a want a more "Expert" opinion.
thank you
thank you
Car: '89 Firebird
Engine: 7.0L
Re: 302 questions
I'm not educated about current prices and engine builders. But I would suspect you could get a relatively inexpensive new engine from GM Goodwrench. Just a basic partial engine for a truck or something like that. Then you find a used set of Vortec clyinder heads and intake manifold to swap out, sell the original 'new' heads and buy a more aggressive camshaft. Something like a Comp Cams Xtreme Energy in the range of 260 - 270 degrees of duration at 0.05 inch lift. This will be a strong running engine around 360- 380 Hp and still behave well with a stock transmission and torque converter.
Do some reading on V8 swaps on this board. You will need to know what you're up against before spending any money. Honestly, it might be cheaper to begin with a V8 car in the first place.
Re: 302 questions
Or you can build a real 302. You use a 350 blockand pistons and 4.3 liter crank/rods.
With the right supporting bits you can have a 7K+ redline.
Might not be the most effective way to power an F body but it'll be a blast.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Most of your questions are answered in the V6 to V8 swap sticky in the top section of this forum.
$250 is probably too much to pay for a 305. There's one in my garage that is available for the hauling.
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
Re: 302 questions
LS Six the 4.3 is a V-6 not a V8 I'm not the best engine builder in the world but I dont to this day know how to drop a V-6 crank into a V-8 block. the proper way to build a 302 Chevy is to use a small journal 327 block and a large journal 283 crank.
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Re: 302 questions
actually the L99 is a 4.3l v8... it is a 305 with a 3 inch stroke to make the 262 cu. in. or the 4.3l... it is also known as the baby LT1... it came in the Caprice...
