L31 engine build
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
L31 engine build
Building a 350 based off of the L31 vortec block. I've got a holley steath ram, SDPC vortec heads, LT4 hot cam, and custom chip. What do you guys think about this setup? I'm only switching out the shortblock (which was a 2bolt 355) for the L31. Will i have to reprogram the computer? Also im thinking about reusing the cam, what are some other better cam options? (that wouldnt require the computer to be reprogrammed?)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Changing out the shortblock, retaining everything else including the cam, won't require any reprogramming.
Curious why you're doing this.
Car: '89 IROC-Z
Engine: 355
Re: L31 engine build
The motor had a rod knock but we never found any spun bearings. Any way thats getting replaced with the new L31 shortblock and my neighbor thinks I should get a new cam and says I can't reuse it. Visually it looks fine though. I'm thinking like 400hp with this setup and good exhaust.
Terrell351
06-13-2021 01:13 PM
84z96L31vortec
08-20-2017 12:16 AM
