oil pressure switch
Car: 91 Chevy Camaro
Engine: 5.7L 440hp 450FBT
Transmission: WC T-5
Axle/Gears: 3.73 Rear end
oil pressure switch
I am wiring up the stock gauge assembly my self. I got all the gauges to work all put the oil pressure gauge. IT works but it goes pass the 60 mark. What I did was put a oil pressure switch out of a 82 camaro. Which I got from checkers. What I need is a one wire oil pressure switch that will work for a 91 camaro. Any help
Scotty
Scotty
Car: 1984 Z28
Engine: 468 Ci
Transmission: T-5 (Until it breaks)
Axle/Gears: 3.73 posi
Re: oil pressure switch
All of your older oil sending units( one for 84 camaro 305 should work) were one wire, but the could be for either 30psi or 60psi gauges so youll need to be spacific when getting one
ambainb
04-25-2016 09:21 PM
TA8487
08-16-2015 12:21 PM
