84 350
Old 04-09-2008, 02:28 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
84 350
im looking at a 350 from a 84 vette c/f inj. will this work in my 85 iroc w/ all of my tpi stuff installed?
Old 04-09-2008, 03:29 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Yes, but you may need to change the oil pan/oil pump, and most likely the front accessories.
Old 04-09-2008, 03:36 PM
Re: 84 350
is it worth installing as a temp while i build a motor? what kind of performance did those things come with?
Old 04-09-2008, 03:54 PM
five7kid's Avatar
Engine: LS1/LQ4
A mind-numbing 205 HP with the cross-fire.
(At least it was faster than the '83 Vette. . . )
Old 04-09-2008, 03:56 PM
Re: 84 350
would that # change if i use my heads and tpi off my blown engine?
Old 04-09-2008, 04:02 PM
five7kid's Avatar
Engine: LS1/LQ4
It would probably be improved with cam and TPI alone. Not sure about the heads; if it's just temporary, I don't think I'd bother.
Old 04-09-2008, 04:06 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 84 350
lol good one....i wonder how many people will miss that....ok u shouldnt have to change the oil pump and pan... ive swapped a cpl 80s model vette engines into third gens and never had an oil pan/pump fitment problem... 5.7 kid is right bout the accesories though for sure, but just use the ones u have. your tpi stuff will bolt up but im assuming your tpi is a 5.0 if so youll need to get the bigger injectors and everything else tha goes with swappin to a 5.7....hope that helps....
Old 04-09-2008, 04:23 PM
five7kid's Avatar
Engine: LS1/LQ4
No personal experience with Vette engines, just what's been said on this Board about Vette TPI engines. I don't know if that means all C4, or just TPI. I would guess C4, which is why I mentioned it (and put the caveat on it).
Bubbajones_ya
07-06-2024 08:32 PM
TX-SleeperC5
02-24-2016 01:34 PM
FormulasOnly
09-10-2015 09:07 PM
FtrSpeedy
09-07-2015 12:11 PM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: 84 350
