Is this a good build?
#51
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Is this a good build?
Thanks for clearing that up for me.
#52
Car: 1992 RS 6spd
MSD-8362 MSD Street Fire HEI Distributors
Distributor, Street Fire HEI, Magnetic Pickup, Vacuum/ Mechanical Advance, Chevy, Big/ Small Block, Each
Today$159.99
Will this one work in my application? I almost hit purchase now, but realized I may want to wait and see what you guys think.
Today$159.99
#54
Car: 1992 RS 6spd
Okay cool. Thanks for the help bro.
#55
Car: 1992 RS 6spd
Okay I'm ordering all of my stuff that I haven't gotten to this week, and realized something. I have no pushrods. What do I do about this, there are about a million different lengths, and two different styles, cup or ball? And they are made from steel, chrome moly, or hardened? Confusing, how do I know which length I would need, which style, and lastly what should they be made out of?
#56
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You have to wait until things are assembled to measure the correct length of pushrods you'll need.
#60
Car: 1992 RS 6spd
Oh and with everything I'm doing, am I going to be able to use my stock guage cluster?
#62
Car: 1992 RS 6spd
Okay good. Basically what I was asking is if the guage cluster was part of my computer, cause when I swap the motor it's not going to be CC.
#63
Engine: 383 Carb
Transmission: 4L60
The computer and the gauges have nothing to do with each other.
#64
Car: 1992 RS 6spd
Okay cool. Thanks man. Doing this swap is really opening my eyes to how little I "actually" know know about my car lol.
#65
Car: 1992 RS 6spd
Okay, I think I'm down to my last question as for parts buying. I have a problem spending money on an intake manifold, that has the same specs as one made by summit. The part numbers are Sum-226019 and EDL-7516. They both have a 1,500-6,000 RPM range, both for vortec, and both made of aluminum. The only difference is the Edelbrock on is the "air-gap" type. Does it really help that much that I'd spend the extra money on it?
Or should I just go single plane?
#66
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Look again - the Summit manifold is also an "air gap" design. "For even more power, we added an open area under the plenum, which provides airflow to keep the fuel/air charge cooler." They can't call it "air gap", because that is an Edelbrock registered trademark.
Single plane on the street is a poor choice.
#67
Car: 1992 RS 6spd
Thanks Five7kid, I honestly didn't see that in the ad for the summit plenum.
#68
Car: 1992 RS 6spd
Okay so I know it has been a while, but I scrapped the vortec idea about 3 months ago because I didn't like how they pulled compared to my friends AFR 195 eliminators. I got everything else I said I was going to, but on a street pull he got me by at least two cars with the AFR's, and a holley 750DP. He was also in a Monte Carlo, which I'm pretty sure is heavier. I was dissapointed. If I were to go to the AFR 195's, would I have to pick a new cam, or is my Voodoo 60103 still a good choice?
#69
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
In addition, what are the rest of the specs on your car? Suspension goes a LONG way into making a car fast. It's no sense in dropping in a 500 hp motor if you don't have posi.
#70
Car: 1992 RS 6spd
I wasn't disappointed in the Vortecs they did their job. More so the fact that I thought I was gonna beat him.
Good point on the rear, I need to update my info. I have a 10 bolt posi with 373s.
