serpentine setup problem
Car: 85 iroc clone
Engine: Carb'd 350 4 bolt main
Transmission: 700r4 2200 stall
Axle/Gears: 9 Bolt BW 3.45
so i bought an 85 camaro with no motor or anything so i dropped a 350 in it and just finished test fitting the serpentine setup from my 89 iroc on the motor and now have a slight fitment problem with my alternator i have tall valve covers and the stud on the back of the alternator hits the valve cover and does not alow me to get it into place has anyone else run into this problem? if so how did you deal with it?
Mike
Mike
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: serpentine setup problem
If the valve cover is aluminum like mine was, I just took a ball peen hammer to the valve cover and made a small indentation, worked perfect. If you don't like that method, Their are other alternators available that are clocked differently, that will have the stud clear the valve cover.
Car: 85 iroc clone
i think before i take a hammer to it ill see if i can pick one up with the stud in a different location but if i cant the ball peen hammer sounds like an alright way to go thanks alot
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need to get a new alternator, you can re-clock the one you've got now.
Engine: 383 Carb
Transmission: 4L60
Take the case bolts out, twist the case halves into a different alignment, put the case bolts back in.
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
i took a hacksaw to the bolt. you can do the same with a dremel. just put the nut on before you cut it off so you can rethread after you cut it.
worked for me
worked for me
Car: 85 iroc clone
i never updated this from... when i posted it i did re clock the alternator and that has worked fantastically, just having other issues now but working them out as well haha thanks for all the replys
evilstuie
01-09-2020 08:29 PM
evilstuie
04-14-2016 08:52 PM
mustangdmurder
08-21-2015 07:17 PM
