Lt1 Experts inside for some help....
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
ok....i have a 355 in my car...old school block style from motown...built motor for a blower....my frends friend is sellng a procharger of a lt1....perfect price and timing, just need to know if the bolt holes are in the same spot on a lt1 gen motor and a older styles 350....so i know if the brakets that hold the blower on the head and motor are the same and i can use this kit....anyone with any clue....let me know.....
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Lt1 Experts inside for some help....
The blower should work, but you may have to get the mounting brackets for the older engine. I believe the LT1 has the mounting holes a little off (for the extra brackets) than a standard SBC.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The supercharger itself will work (I know a guy who has one on an '85 Trans Am TPI) but the brackets are different. If you just get the brackets for a 3rdgen F-body you should be fine.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Even if it would bolt to your engine, from the research i've done for wanting to put a blower on an LT1 thirdgen, im quite sure, that it wouldnt fit due to the location of the steering box, i've never actually tried to bolt one on personally, but i've researched it a decent bit and im quite confident there just isnt enough room to get it installed.
1 Post
He doesn't have an LT1 in his car - the supercharger kit he's considering getting for his car is meant for an LT1 f-body.
Car: 93 240SX
Engine: LQ9
Thats why I said "even if it would bolt to your engine"
Im saying that either way, reguardless of the block, im very sure the mounting location using the LT1 kits bracketry will not allow fitment into a thirdgen with the steering box.
1 Post
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
What kind of accessories are you running? Im kind of confused what you combo is, and what type of intake you have. If Im not mistaken the blower mounts rather high so I wouldnt think fitment would be a problem, I would think it's more like accessory drive and intake type.
If it's an LT1 blower in a thirdgen with a gen 1, then you need to use a bracket for the type accessories on the car. Im assuming it's a TPI intake...so a TPI blower would be best.
Car: 87 IROC Z28
ok, its a carbed 355 motor with forged internal and aluminum victor jr heads and intake and a 750 double pumper, i can do the plumbing from the blower to the carb easily, i just need to know if the lt1 blower braket will work with a 350 setup like mine...and i dont have anything but a power steering pump and a altenator and a water pumo lol....so yes or no...or i have to buy teh 350 braket from procharger...and its a d1sc
1 Post
No. LT1's have different accessories, different drive coming off the crank. U need a TPI bracket, I assume you have the pre-88 style?
I bet you could make a blower kit for a 1987 305 TBI car work REALLY well. Just swap the head unit.
Car: 87 IROC Z28
well i want to use everything i can from his lt1 kit that i can, like craqnk pulley if i can use that be nice and everything else i can make or use, i just have to buy the tpi braket to hold the actual compressor.????
1 Post
Car: 1987 GTA
Crank pully will be different since the LT1 uses a different type of crank hub/pully unit, you'll need to use a pully for a gen 1 SBC.
Car: 87 IROC Z28
so im gettin so far i need the crank pulley and the compressor braket for a old skool sbc kit from procharger...wnything else....that anyone can think of thats differ that might bite me in the ***...
KO1
16
10-15-2015 05:00 PM
