TBI-CARB swap tbi throttle cable too long?
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i thought i remeber reading on here that usually a tbi throttle cable works well for tbi/tpi-carb swaps but my tbi cable is over an inch too long. i have a holley carb and the throttle cable is adjusted all the way and its still too long. i was wondering if anybody else is or did experience anythign like this. any input would be appreciated. thanks
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Re: TBI-CARB swap tbi throttle cable too long?
Go to the Chevy dealer and ask them for the TV and the throttle cables for an 86 LG4 (Carbed) Z/28.
I used both Holley carb brackets pns 510-20-95 and 510-20-121 with those cables and it all fits perfectly.
Holley should make a bracket that will also mount the cruise control cable.
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
hey thanks for the info but my car is stick shift so i dont need the 510-20-121 tranny kickdown bracket right?
and what do u think the cost of the throttle cable will be from the dealer?
With the manual trans there is no need for the relocation bracket.
The throttle cable is not very expesive. I think it was less than $25 and they should be able to get it in a day or two.
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
just wanted to let you guys know that i got a thorttle cable for an 86 lg4 and it works perfectly thanks for all your help!
9192camaro
16
02-03-2019 12:21 AM
