L99 or LT1?
Old 11-20-2007 | 01:34 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
L99 or LT1?
I was wondering if the blocks are marked with the engine size like most 350 or 305 are. Because I found a good deal on an LT1 from a caprice and I just want to make sure it is the 350 version before I buy it.
Old 11-20-2007 | 02:10 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: L99 or LT1?
I will be marked 5.7L if it's a 5.7 LT1. I believe the 4.3's are marked the same.
Old 11-20-2007 | 02:48 PM
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: L99 or LT1?
Ok thanks a lot.
Old 11-22-2007 | 07:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: L99 or LT1?
Its will be marked, as said above, on the bellhousing flange, drivers side.
88SS6SPEED
11-11-2015 08:05 AM
L0tuS
10-04-2015 09:07 AM
WejaZ28
10-03-2015 08:38 PM
CatmanFS
09-19-2015 10:00 AM
L0tuS
09-05-2015 12:16 AM
