Swap 305 to High HP 350
1 Post
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
I have searched posts for any info on this but couldn't find any.
I have a 83 z-28 with the underpowered LG4 305. I have 350 on the engine stand which I'm going to build over the winter.
How much HP can this car handle without breaking the t- roofs or twisting the roof ? I hear lots of people talking about this but I cant find any stats at all.
I want to build the 350 up to 325 to 350 hp.
Any help or a point in the right direction would be appreiciated.
Thx..
Thx..
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Welcome aboard thirdgen.org.
IMO, subframe connectors are a must-do for these cars, regardless of T-top or hardtop, regardless of power. Put $200 in your budget for them right now.
350 HP would be a cakewalk with SFC's. Of course, 10-bolt improvements are always in order, and poly engine and transmission mounts are superior to stock type rubber. After that, it's more about making it work better, not so much making it capable of handling the power. Along those lines, poly suspension bushings make a huge difference in the way the car behaves, as do boxed or tubular lower control arms and aftermarket torque arm.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Swap 305 to High HP 350
Agreed, I've seen box stock 350 TPI cars put cracks in the roof's at the back of the passenger and drivers side windows. The more power you put out and the stickier the tire you use, the worse you make the problem. Get the subframe connectors in there first before you start doing power mods.
1 Post
Car: 1983 Z28
So if I put in a good set of SFC's and poly suspension upgrades the roofline will not tweak enough to cause t-roof breakage?. I understand that the car will handle much better withthe SFC's , and the rear end is making noise anyway so I will replace it with a positraction. The car currently has a THM 350 in it. I will be replacing with a 700r4 at the time of the engine swap.
I have had some 350 hp to 400 hp cars in the past 65 chevelle ss, and a 66 Pontiac Tempest with a 302 Zapper. Both of these cars had lots of torque and twist through the frames. I just don't want to spend the cash on the motor and have the roofs breaking!!!! :-)...
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Even my V6 engines break the top without subframe connectors.
GET THEM!!
1 Post
Car: 1983 Z28
Thanks guys.....My car has no cracks and I want to keep it that way!!!!
