Crate 383/450HP
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Trans Am, 2003 Z06 Vette
Engine: zz383
Axle/Gears: 9" moser 3.70
Crate 383/450HP
Hi,
I am looking to put a 383 into an 84 T/A and came across a pretty good deal. Just wanted to see what you thought about these specs - the engine is selling for $1500 cheaper than Jegs zz383:
This engine would be EXCELLENT for a Street/Strip car, Street Rod, or Pickup Truck. With 450HP @ 5500rpm and 460ft lbs of torque @ 4500rpm this engine has a rough idle and will run on leaded or unleaded 91 Octane pump fuel.
The balanced rotating assembly (typically includes crankshaft, pistons, rings, connecting rods, rod bearings, balancer, and flexplate) featured in this engine:
- 3.750" stroke crank
- 5.7" forged big beam rods with ARP rod bolts
- 10 to 1 compression hypereutectic flat top pistons
- Seasoned 4-bolt main block with one piece rear main seal to prevent oil leaks
- Block has provision for mechanical fuel pump
- Engine comes with flexplate
- Deck head gasket surface on block to ensure a good seal
- New Hydraulic flat tappet cam with .512" valve lift
- New Dart/World heart-shaped chamber, 200cc intake runners, cast iron, straight plug heads with 2.02"Int/1.600"Exh swirl polished stainless valves with undercut stems for even more flow
- Heads cast with extra thick deck surface
- Hardened exhaust seats for use with both leaded or unleaded fuels
- New 1.440" High performance springs set up to match cam
- New Chrome moly retainers and hardened keepers
- New High temperature valve seals
- New Bronze valve guides
- New Screw-in rocker studs with guide plates
- New Roller rocker arms
- New Hardened push rods
- New Perfect Circle rings
- New Double row timing set
- New High volume oil pump with welded big pickup screen and steel drive shaft and steel guide
- New Revolutionary 1-pc design molded rubber oil pan gasket with load limiters to prevent over-tightening and higher temperature resistance than standard cork-rubber gaskets
- New Brass expansion plugs
- New Edelbrock Victor Jr aluminum intake manifold
- All parts are painted separately before assembly for that show quality look
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Sounds like an eBay special - all the right words, the parts you actually get are a different matter.
Proceed only with extreme caution.
Engine: zz383
Re: Crate 383/450HP
You hit the nail right on the head...it is an Ebay engine. The only reason I am contemplating it is because the guy has 100% feedback with 500 transactions.
I think will just go the safe route and buy it new from GM.
Thanks for your input.
Engine: LS1/LQ4
That's a decent feedback rating. If they were scammers, it would be reflected in their rating.
But, GM is pretty safe.
RedLeader289
05-28-2019 01:47 PM
