1973 Vette 350 into 86 Z28 w/ orig 305?
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Hey guys new here just picked my 86 z28 w/ its orig 305 on the wya out... its a winter proj and i found a old 350 block from a 73 vette that was running to rebuild.. i'm just wondering i can just drop it in or do i have to red the motor mounts on my car?
any advice also would be great.
1986 Z28 T-Tops Camaro..engine knocks to hellbut i can still spin the tires when i mash on the gas!!!
John
John
Received 1,862 Likes
Re: 1973 Vette 350 into 86 Z28 w/ orig 305?
It's a small block Chevy, just like any other small block Chevy. Nothing whatsoever in any shape form or fashion is altered by being associated with the "V" buzzword. The motor mounts are in the same place they have been in on the SBC since about 1958.
There is likewise, nothing whatsoever that is "special", "different", "better", or anything else (not even "worse"), about a 350 that has recently been in a 73 Vette (or even one that the factory themselves had put in a 73 Vette), as compared to one that has been in a 75 C-10 pickup or a 76 Caprice station wagon or any other chassis. I hope you didn't pay extra to get the "Vette" one, like if there was one out of a 74 Nova 2-barrel sitting right next to it that he would have sold cheaper but you got this one instead because it was "from a Vette", because it's just like any other. The cast iron IMMEDIATELY forgot that it had ever been wrapped in fiberglass, the instant it came out. The magic went away.
So yeah, it'll go right in; you'll only have 2 issues.
The earlier-model style of dipstick tube location, which is totally incomaptible with the exhaust manifolds for these cars. But since no one in his right mind would swap motors and leave those in, your headers will take care of that.
Your 86 should have the 1-pc rear main seal, but the old motor has the 2-pc; the flywheel or flex plate will have a different bolt pattern. You'll need to get the one for a 83-85 Camaro/Firebird V8.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Use the motor mounts from the original 305, the vette engine might come with "weird" ones.
Also use the 305 starter, make sure the 350 has the right bolt pattern to use a 305 starter (for use with the smaller flywheel/flexplate)
I might add, do that BEFORE you put the engine in the car.
Pac J
05-17-2020 10:44 AM
