LS1/T56 in the garage
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Got a call Friday morning from the freight company that the engine/transmission had arrived. Went in the afternoon to pick it up, got it home and unloaded and unpacked. Only issue I see so far is the power steering pump pulley is busted, the cooler was packed in front of it and the whole thing wrapped in several layers of plastic wrap. It could have been bumped into and no evidence left. I'll contact the seller and see if he has a replacement, otherwise I'll just find one myself.
One more race in 2 weeks for the Camaro, then the project can begin. A lot of stuff to do, still need the swap install parts, and need to learn a lot (what are all those connectors for????).
Car: 1989 RS
Engine: 350 c.i., carbureted
Transmission: th700r/4
Re: LS1/T56 in the garage
Congrats on the new toy arriving!
I hope to do exactly what you are about to do to my '82 Berlinetta. I have a lot of learning to do on the swap, though.
Originally Posted by five7kid
Got a call Friday morning from the freight company that the engine/transmission had arrived. Went in the afternoon to pick it up, got it home and unloaded and unpacked. Only issue I see so far is the power steering pump pulley is busted, the cooler was packed in front of it and the whole thing wrapped in several layers of plastic wrap. It could have been bumped into and no evidence left. I'll contact the seller and see if he has a replacement, otherwise I'll just find one myself....
1 Post
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
your having tooo much fun without mecongrats tho.
Engine: LS1/LQ4
Am I reading too much into the shifter **** logo?
Engine: LS1/LQ4
Ask, and ye shall receive. . .
Hope that's good enough. I couldn't see any markings on it.
Oh, forgot A.I.R. delete in the list of "doing's".
1 Post
I'm still jealous!!
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Yup, that would be a Hurst shifter, I have one in my T56 and love the crispness of it, people around here have tried the B&M Ripper, Pro 5.0, Hurst and they all love the Hurst.
Engine: LS1/LQ4
I've played with it a little, feels crisp to me, but can't say a whole lot with it sitting on the floor in the garage. . .
Where's reverse?
Where's reverse?
Engine: LS1/LQ4
I emailed the seller about the pulley. He said he normally doesn't leave the cooler there, and won't again. He's sending me a replacement pulley next week.
So far, he's lived up to everything he said. Helps explain how he built up his 100% positive, 1160 feed back score.
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
1 Post
Car: 1987 GTA
It will be rough putting it in reverse without power to the reverse lockout solinoid but it will go in.
Engine: LS1/LQ4
I wondered about that. What activates/deactivates the solenoid? Vehicle speed?
Car: 92 rs
Engine: 305 for the moment
Transmission: 5 spd
Where did you get the engine and how much if you dont mind me asking. Looking for a suitable engine for me to start my swap in my 92 rs.
Engine: LS1/LQ4
eBay. 100% positive, 1160 feedback seller. $4k plus shipping (which was less than I expected). He's FedEx'd the replacement pulley. His eBay username includes "LS1".
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
looking good..
the PCM does it for you... and yea, it uses vehicle speed.. anything over 3mph or something like that, and its locked out.
really, when driving, you forget it does it for you since, you never accidently go into reverse, and its effortless to put it in reverse when you need it.
and yea, thats a hurst shifter.... they're nice.
if you take the PCM part of the harness, and roll it out to the passenger side, next to the motor, there should be 3 underhood connectors near by, 2 in car connectors (unless they cut them off) and a purple single wire connector.
thoes are the only connectors you need to touch on that whole harness. everything else is attached to something on the motor or transmission...
Linson
10-01-2015 09:50 PM
