chevy 350 swap
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
chevy 350 swap
looking at this engine. http://rebuilt-auto-engines.com/cgi-...45107480354.1e
out of these choices what would you guys suggest?
crank casting numbers -
333882, 376445, 462624, 1407114
block casting numbers -
3970010, 14016379, 366245
head casting numbers - 310514, 3932442
any combo is the same price, but i was having trouble finding what some of these casting numbers were. thanks for the help.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What are you putting it in?
It doesn't make much sense to specify one for a 1969 Camaro. There wasn't anything special about that 350. You can do a lot better with later stuff like http://rebuilt-auto-engines.com/cgi-...24107472034.00 with 083 heads. They'll put a nice cam in it if you ask. That particular engine is one-piece rear main seal and center bolt valve covers, and since they don't come with tin or even the rear main seal carrier, you'd better have that stuff available if you do go for that engine. But, those 083 heads are much better than anything they had in 1969.
NinjaNife
08-23-2015 12:49 PM
