What does EGR mean?
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
What does EGR mean?
what does it mean, and what does it stand for, just curious. Thanks!
Received 1,811 Likes
Re: What does EGR mean?
Exhaust Gas Recirculation....
It is an emissions-control system that recycles a small amount of exhaust gas back into the intake, to "poison" the air/fuel misture a little, to reduce peak cyl pressures, to reduce the formation of oxides of nitrogen (a major component of LA type smog).
It can also be used to attain high operating efficiency under low loads in a high-compression motor using too low a grade of fuel; it allows the use of more timing advance under these conditions (cruising, cat-pee regular gas) without causing pinging or pre-ignition. As such, it can be turned into a benefit, with modern control systems (computers).
Transmission: th350
ok, its jsut kinda like emission control, thanks.
HoosierinWA
10-07-2015 10:15 AM
