build a 350 or buy a ls1
Car: 88 Trans Am
i have a 350 block bare, what is the best route build the engine for 400hp or buy an ls1 and nitris it. because building the engine i still think ill have to buy a tranny so what you think, and im also trying to keep it smog legal
1 Post
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Do you have to keep it smog legal? If so I'd imagine that would be alot simpler with the ls-1, also fuel econ. would be much better with the ls-1. If you can afford and know what all your getting into with the ls-1 you should go for it.
Although a 350 with a decent cam and vortec heads can achieve 400 hp and more torque, reliably and pretty inexpensively. Plus tuning a carb is a bit simpler than a computer, unless you were planning on fuel injection on the 350-which would also be cool.
